Question about Briggs & Stratton 8,000 Watt 16 Hp Portable Generator #1934
Brand new briggs & Stratton 8000 watt generator....
Will not provide any power. None of the circuit breakers are tripped. The rocker switch circuit breaker switch is on. I have tried several different appliances that all work fine when plugged in elsewhere.
  • gatorexpress Feb 28, 2009
    Same problem, less than 40 hours on unit but it is 2 1/ years old. Service department sain wire came loose in the stator and shorted it out. They said it was not worth fixing. Appparenltly Troybuilt has succumbed to the China market and now sells JUNK. Lowes was the store I purchase it at.
  • Anonymous Mar 21, 2014
    Circuit breaker isn't working
  • 169 Answers
I posted an answer that should help here.
Posted on Dec 08, 2008
How to test for a shorted generator stator
Sounds like you have a dead short. Check the outlets for any debris, metal or copper. Check the backside if the outlet for anything grounding onto the unit. The breaker is tripping to protect the outlet and anything plugged into it. The fire shooting out of the outlet is an arc flash caused by the dead short. You can also try disconnecting and replacing the outlet . If the problem persists, disconnect the starter and try to bench test it with a multimeter. I hope this helps. Good luck.
Oct 02, 2014 | Briggs & Stratton Electrical Supplies
Troubleshoot troy bilt generator
Check that the GFI receptical is not tripped Check that there are no blown fuses or tripped breakers Verify that the engine is running at full RPM If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Aug 30, 2014 | Briggs Stratton Portable Generator 305cc...
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
Lights went out breaker was thrower switched breaker to on several times when I came in tv would not come on electricity is good to it so is their a fuse and where is it on tv or is there a nother place on...
Pull the TV plug out of the electrical outlet. In fact, pull all plugs from all nearby receptacles. Try the circuit breaker. If it still trips, pull more plugs from the receptacles untill the circuit breaker no longer trips. Reverse the process to isolate the plug that is causing the circuit breaker to trip. Repair broken item.
Apr 12, 2013 | Televison & Video
Chainsaw trips circuit breaker
Does the circuit breaker trip before squeezing the switch? Check the power cord - there's a short
Does the chain move freely before squeezing the switch? If not, and the circuit breaker trips while squeezing the switch, your chain is too tight.
Bottom line - tell us when the breaker trips and what you were doing when it tripped.
Dec 07, 2012 | Craftsman 16" Electric Chainsaw Chain Saw...
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
I have a briggs and stratton 8500/5500 generator which I am using to power an air conditioner on a camper trailer. I just recently started having a problem where the one circuit breaker keeps tripping when...
Hello, First figure out what the load per leg is on your generator. Are you using the 240 Volts because this is two 120 AC volts legs and they are 120 degrees out of phase with each other.
You will need to figure what the power factor is for each phase on this generator. To figure the power/wattage by using ohm's law. Voltage times Current will give you Watts. Example: If the generator is generator 240 volts the maximum current available is about 23 amps. The maximum current for 120 volts will 46 amps. Therefore, the maximum current per 120 volt circuit is 23 amps for one circuit and 23 amps for the second 120 circuit..
I would try replacing the circuit breaker with the same amperage breaker. Also, watch what the generator load is per circuit. You can install current meter for each circuit. This will give a good indication of which circuit is pulling more load than the other circuit. GB...stewbison
Sep 06, 2011 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton 8,000 Watt 16 Hp Portable Generator #1934 Logo
844 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
