Question about Toshiba Satellite P100 Notebook
Startup display problem P100 PSPA3E
Last week my P100 PSPA3E suddenly had problems when I restarted the WIN XP. display was black, no backlight, Harddisk was running, I think windows started correctly, when I inserted my passw. I could hear accoustic signal of windows start (lights were normally on). When I shuted down the system and waited for some hours at least over night, it was possible to make one start with display coming.Display showed no errors, verything seemed to be fine but restart made the same problems as discribed. So I tried to plug in an external monitor to the AVI and later on to the DVI port - no reaction - external TFT says no signal and goes to sleep modus. Switching the Fn + F5 or Fn + other F functions takes no effect. So I decided to flash the bios with the latest version from Toshiba homepage, everything was well done, same problem at restart. So I uninstalled the nvidia grafic driver and installed the latest version from Toshiba homepage. One normal start was possible, this morning only the backlight was on but display showed
nothing. Windows start ok. At restart no reaction from display, everything stays black. When laptop is turned off I also remove the battery and set it in before restart. The only thing I am missing at start
is the sound of switching the display on.
  • 93 Answers
Hi, ok clearly for the symptom of what describes modal to his portable , I understand that the fault of his equipment comes from the card of video, which not this on board but it is separated, if the problem that he presents also happens for the VGA port and for the DVI port, this indicates that the problem that his equipment presents into in the system board.
Posted on Jan 09, 2009
When Win XP restarts display is black.
Have you considered a Exorcist? Have you cleaned the fan, vents, heatsink recently? Take a look at this it may help in troubleshooting: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Apr 28, 2013 | Acer Aspire 1640Z Notebook
No Display, No Backlight Problem in Acer Aspire 5720G
If you hit F8 on the logo screen and choose safe mode. After startup go into "mycomputer" and right click on C and choose properties. Select the "tools" tab and hit "check now" to scan for windows errors. After restarting it should work.
Mar 13, 2013 | Computers & Internet
Sharp MX-2300N - can only print on computer restart
You will have to contact Sharp's service department.
Apr 30, 2012 | Sharp MX-2300N Color Copier
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
Dear Sir, Machine: Lenovo Ideapad Z560 (Blue Screen) Cannot start computer I had dual operating system XP & Win 7 on my computer, while using Internet (XP System) I got Memory Dump Error system...
your windows operating system is probably corrupt you cannot recover all of your files,
unless you have an file recovery software.
re format your disk c and put an operating system again.
Mar 21, 2011 | Lenovo IdeaPad Z560 Laptop Computer -...
My eee pc suddenly had screen problem a week ago--- when it boots up the screen is solid fluorescent green, then as Win XP starts there wide vertical bands appear, and finally what i'm left with is an...
I just had a smilar problem with the vertical lines and resolved it by disabling the display adapter, the display driver was corrupted, and i am using it to type right now and no problems. Go to the device manager and disable the disp0lay driver by right clicking on it and selecting un9install and restart. I could hardly see through the lines but I did it and it worked. Windows automatically comes with drivers from many manufacturers for many devices and it seemed it has one for mine and it worked as my display adapter is still disabled but my graphics are perfect....All the best!
Aug 17, 2010 | Computers & Internet
XP freezing at startup.
U just check out that how many free memory in your os installed drive...
if few so delet some unimportant program.....
second---------->>
in start up first system32 is running so u have any virus in this folder..........
Third-------->>>
and other u start task manager at startup of windows and go to in processes .....
now u so 4 line .....
in last line Mem Usage displayed u show all running processes......
so just find out which program usage more memory...
now select it and right click their and click on end process..
now go in control panel and remove this program .
ok
have a good day
Jun 15, 2009 | Toshiba Satellite P100 Notebook
Display
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Oct 10, 2007 | Acer Aspire 5002WLMi Notebook
Display backlight problem
i have the same problem, i thought it completely blacked out, but i realized it was just the main backlight. i can see it if i hold a flashlight to it, but i tried everything to fix it, and ive had no luck.
Sep 21, 2007 | LG VX8300 Cellular Phone
Open Questions:
Toshiba Satellite P100 Notebook Logo
278 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
