Back to:
Tags:
Nikon N80 35mm SLR Camera
Camera won't turn on what can i do (yestreday it... (by 14 users)
By Beresford - usenet poster
Camera won't turn on what can i do (yestreday it worked fine, HELP)?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Comment by Guest, posted on Sep 04, 2008
Camera won't turn on. I changed the battery and I still have and error sign and
picture of a battery with vf beside it.
Comment by gmgrad2005, posted on Aug 18, 2008
My camera has been working fine, then all of a sudden it died. Changed batteries and nothing, so I even had the batteries tested and still nothing. What can I do, or where do I take the camera?
Comment by sally_thom, posted on Jul 23, 2008
My camera won't turn on. I've changed the batteries, but still nothing. If the camera has died I want to get the film out to have it processed. What's the best way to do this.
Comment by rumiko_masak, posted on Jun 24, 2008
me and my friend used his polaroid but it doesnt seem to wanna turn on and we dont have a manual
Comment by Guest, posted on Jun 18, 2008
My Olympus Superzoom 700XB does not switch on . No initial winding ,
shutter does not operate.Please advise
Checked batteries and replaced.
Clarification Request
by Mitchell94, posted on May 07, 2008
I've already replaced the batteries, and unless I'm mistaken, I see no AC adaptor on an N75...its not digital.....has anyone figured out a solution for this?
Best Solution
posted on Aug 08, 2005
Helpful (85)
2Pansy
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
1. Check batteries.
2. Connect camera to an AC adapter.
3. Remove all batteries, disconnect AC adapter, wait a minute, reinsert batteries and reconnect adapter. Turn on camera.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Camera won't turn on what can i do (yestreday it worked fine, HELP)?:
I don't want to Accept this solution
Solution #2
posted on Aug 26, 2008
Not Rated (0)
Gizmofiddler
Rating: 0%, 0 votes
Go into a very dark room and open the film loading door slightly, then close it. If you hear the motor wind the film, then all is well. This may unjam the mechanism and get it going again. Try it now. The current and adjacent frames may come out foggy if too much light enters the camera.
Thank You!
Solution #3
posted on Jul 24, 2008
Not Rated (0)
eltroman
Rank:Wiz Wiz
Rating: 83%, 114 votes
Open the camera back in a compete darkened room.
Then remove the film out.
atdlee@netzero
Thank You!
Solution #4
posted on Jun 01, 2008
Not Rated (0)
Wackett
Rating: 0%, 0 votes
do you need a charger for this camera
Thank You!
Solution #5
posted on Feb 09, 2008
Not Rated (0)
the crab
Rating: 0%, 0 votes
If you use rechargeable batteries, make sure they are freshly recharged. If they have been sitting for a while, even just a couple of weeks, they may have discharged. Also, some new rechargeable batteries need charging before use.
Thank You!
Solution #6
posted on Sep 20, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Throw Cyntar in trash. get a new HP or Nikon.
Thank You!
Solution #7
posted on Jun 23, 2007
Not Rated (0)
Canon4me
Rating: 0%, 0 votes
I had the same problem. I found that I had a roll of film inside but not wound to the other side. I put a new roll in, after the camera wound the film to the other side it was fine. I think this will also happen if you don not have a roll of film loaded.
Thank You!
Solution #8
Not Rated (0)
Canon4me
Rating: 0%, 0 votes
I had the same problem. I found that I had a roll of film inside but not wound to the other side. I think this will also happen if you don not have a roll of film loaded.
Thank You!
Solution #9
posted on May 30, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
The contax rts3 has a dc/dc convertor. when this integrated circuit fails, camera will not power up, even though it worked yesterday. the ideal solution is to replace the ic; the quick & dirty fix is to connect the camera power to an external regulated supply. after being connected for a couple of days, the camera will resume working. NEVER remove batteries for more than 10 minutes from now on.
Thank You!
Can you Help with these Film Cameras problems?
so i'm just firing up my dads old hand me down camera; i...
I took my camera out the other day to shoot some pics of...
The AF-Assist Illiminator on my N80 stopped working. I...
For some reason my N80 is not always advancing the film...
I recently came across a Nikon N80 everything seems to...
13 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 09, 2008
Will not turn on. Battery light blinks. Replaced batteries still nothing
Comment by Juanitalissa, posted on Jun 02, 2008
My Nikon N70 35mm SLR does not turn on with new batteries. I have not used the camera for a couple years but I have kept it at room temperature in a camera bag. Nothing turns on and I have tried taking the batteries out and putting them back in.
Comment by jahdiel, posted on May 17, 2008
I changed the battery and now it wont do anything, all it does is show the battery status, then it blinks and in the space were it shows the number of pictures taken, it shows " 54" does anyone know what this means? please help!
Comment by Guest, posted on May 08, 2008
Was in the middle of a roll of film when after taking a picture, the film did not advance and in the screen where it tells you how many pictures you have taken, an E is flashing. Bought new battery - this did not help. Then also put in a new roll of film and the E is still flashing and film would not advance.
Comment by ncbenin, posted on Dec 18, 2007
I printed the first set of film which was not clear nor sharp the pictures were very hazy.
I put a new film pressed the shutter release button but it did not return and the lens cover swich is stuck, I can't get the switch to move.
I bought the camera less than a week ago.
I've tried reloading took to Asda were I bought to see if I put the film in right was told I had and that it's gone bad.
Comment by manny5155, posted on Dec 17, 2007
my camara just wont torn on, battery is good flasher is good, have a new film but still not working
Comment by ajgem, posted on Nov 18, 2007
I have the same problem. Mine is new and when I first got it, I placed the batteries in and it turned on, which I knew from the orange indicator light and the sound it would make powering up.
The first time I used it, it was doing the same, though I can't particularly remember if I actually saw a flash. Throughout the same night, it stopped turning on- no light, no sound. So I figured maybe I somehow drained the batteries.
I replaced them, and even with new batteries, the indicator light did not come on and I could not hear the camera powering up.
Comment by suneerayz, posted on Nov 03, 2007
Recently bought Nikon FE camera. I bought new batteries for it, and and inserted them. When i turn the power switch on, a red light shows, and then shuts off when I release the power switch. Any suggestions?
Loading problems.
Repair Service
Find Film Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
