Question about Nikon FM10 35mm SLR Camera
Nikon FM10 shutter wont deploy with lens on.
I haven't used my camera for a while, but it was stored very well. Took it out to use again and the shutter wouldn't deploy. After some tries, got the shutter to deploy without the lens on. But cant seem to get it to work when the lens is on. The lens is the standard 35mm - 70mm. Any ideas on how I can get it to work again?
  • 1 more comment
  • aemden1 Dec 06, 2008
    Hi bart477,
    Thanks for responding, I did repeatedly fire the shutter and eventually it did so quite freely. The problem that I have is that when I attach the lens, the shutter sticks. It relases when I de-attach the lens. I live in Jamaica and we dont have anyone that i know of, that can repair a camera. I would have to travel overseas to get that service. If I have to, then I will, but I was hoping that it maybe wouldthere is something that someone could be done before I book a flight :)
  • aemden1 Dec 15, 2008
    Hi folks,
    Sorry for not getting back to you. Thanks for all the suggestions, unfortunately nothing seems to have worked. The lens aperature moves freely, the camera without the lens attached works as its supposed to. Nonetheless, I am on a flight next week so I'll find a repair man. Thanks again for the all the help!! Happy Holidays and I wish you all a great New Year!
  • Bart Pulverman May 11, 2010
    It sounds like your shutter is sticking. This is a common problem with any camera that has been unused for some time. Before we conclude that having the lens on the camera is a real issue, you need to be sure you fully restore free movement to sticking parts. Repeatedly fire the shutter. About 20 times at each speed. By the way, because the shutter mechanism is mechanical, it is a good idea to do this periodically, even if the camera is frequently used. After you do that, put a lens on the camera and let me know what happened.
    Even if this alone solves the problem, you should probably have your camera checked by a repair man to verify that the actual shutter speeds match the speed you set. For example, when you set your camera to 1/125th second, is the actual shutter speed 1/125th or is it off? A camera repair man can either adjust your shutter or provide you with a compensation chart for your camera.
    Scholar:
  • 185 Answers
Check the lens. Does the diaphragm move freely when you move the f/stops? Put the lens on f/8 or f/16 and push the pin in, it should move freely and close to the f/stop you set. If not the blades may have oil on them. Also if it is free then set the lens to the smallest aperture and if there is a button push it in to lock for auto aperture set.
Posted on Dec 07, 2008
Nikon FM10 will only release shutter with cable
Hello Blair,
I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind.
However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive.
Cordially
May 25, 2014 | Nikon FM10 35mm SLR Camera
My shutter is stuck and i sent it to a service centre and they released itand now the shutter is releasing. but when pictures are printed some pictures are half shadowed so i sent it to a Nikon...
A lens cleaning to remove fungus can be quite expensive. If it is a consumer lens or a cheaper lens then often it can be cheaper to buy a used or sometimes even new lens than for a cleaning of fungus.
As for the shutter - it probably needs to be replaced. It is possible it could be repaired, usually replacement is the better option. Different service centers will charge different amount for this.
But often it is worth it vs buying a new camera.
Nov 13, 2010 | Nikon FM10 35mm SLR Camera
I have a nikon fm10..when changed my lens to 50mm f1:1.8D, i would press the shutter release button, then the shutter will close,just close! i know it suppose to close and open rapidly, (my shutter speed...
Does this fault happen only with that lens? Also, you're wrong about the shutter: it appears you're mistaking the shutter assembly for the lens diaphragm (also known as the "iris").
Older lenses often have sticky diaphragms, usually due to oil migrating onto the individual blades and sticking them together. A sticking diaphragm can interfere with the shutter operation on some SLR's.
Fixing a sticky iris is usually a professional job, but if you're careful then with a simple non-autofocus lens like yours it's often possible to do on a DIY basis but will be very fiddly. The object is to get to the iris blades and to then thoroughly clean them. They're Teflon coated so should slide over each other without lubrication, but their pivots normally need the tiniest bit of lubrication. If you try and fail then you've lost nothing as the lens was effectively scrap anyway and there are plenty of cheap/free replacements around.
Sep 10, 2010 | Nikon FM10 35mm SLR Camera
D40 Nikon
i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
Feb 21, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
HELP APERTURE PROBLEM! When I attach any lens to the Nikon FM10
This is normal. the lens stay at the largest opening so you can see to focus, then the mechanics will close to the setting when the exposure is made. This is part of the reflex in single lens reflex (SLR). This part staying open when you focus keeps lyou from having to open the aperture to focus and then close it to the correct setting to shoot the picture.
Jan 29, 2010 | Nikon FM10 35mm SLR Camera
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
Help, my camera wont take pictures
Did you try pushing the shutter button? It may already be wound. Otherwise, try pushing the rewind button in and holding it while you wind the lever. Now, it MAY be that your at the end of the roll-what does your counter say?
Mar 31, 2007 | Nikon FM10 35mm SLR Camera
Nikon FM10 35mm SLR Camera Logo
151 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
