Question about Zanussi ZCG7680 Gas Kitchen Range
CLOCK & OVEN PROBLEM
Clock & oven prgrammer not lighting up & oven not lighting
  • Anonymous Nov 16, 2007
    magic chef over. Went to turn on the stove top light and the clock and oven timer / settings went balnk. The light and burners work, but the digital display is blank and doesn't work. As a result the oven will not light. Any ideas? Thanx in advance.
  • 258 Answers
How Ironic, we have a Moffat Discovery and exactly the same thing has happend, so we are waiting for a new Zanussi to be delivered.
As the clock timer is linked to the oven it will not light when the clock has broken.
Temporary solutions: So I turned all the electricity to the cooker off and left it a while, when I turned it on still the same problem, but after about 2 hours it comes back on, works for a couple of days then goes off again, (always seems to go out when my missus is planning to cook, so wondering if she' got something to do with it, don't tell her I said that though)
Now trying to switch the clock setting to stop or manual, and when it goes off i'll try and see if the oven lights,
HPC
Posted on Jan 17, 2009
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
Need to repair or replace oven clock for Frigidaire RBE97N-CH wall oven (manuf'd 1968). Synchronous clock motor runs, controls appear to work OK, but clock hangs up, doesn't keep good time. Might be dirt...
The clock is not available anymore. You could remove it and thoroughly soak in WD-40 and Then use a light oil on it after it's completely dry.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 13, 2009 | Fagor 5HA-196 X Single Oven
Oven fan won't switch off
it sounds like the clock on the oven has been adjusted, if the clock has been adjust the fan will continue to "Cool Down" the oven for the period set on the clock, it is also a possibility tht the clock is faulty, is the clock digital or Analouge
Jan 30, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Cannot set clock Model RBS245PDB2
you need to replace the clock timer board..
Aug 09, 2007 | Whirlpool RBS245PDS Electric Single Oven
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
Zanussi ZCG7680 Gas Kitchen Range Logo
655 people viewed this question
Top Zanussi Kitchen Ranges Experts
Paul Bade
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
