Computers & Internet Logo
Posted on Dec 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to figure out the size of a hard drive
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Dec 06, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
1257
Points
22
Open mycomputer then right click on each drive and go for properties . check how much capacity drive it is eg: 9.50 that means 9.5 Gb drive capacity...similarly check each drives capacity and add them up for total hardisks capacity.
Anonymous
Level 2:
  • Expert 340 Answers
Anonymous
Expert
Level 2:
Answers
340
Questions
12
Helped
212220
Points
947
Hi MacLean, and welcome to FixYa,
There is the BIOS way and there is the Windows way:
The BIOS way:
When your computer is booting up, you can interrupt the startup by pressing either esc., F1, Del., F10, or maybe some other key, depending on your pc.
In the setup, you’ll se the disks on your computer, and the size, this size is the factory size, - Bill Gates take a bite and throw it away :-)
The Windows Way:
Rightc click "this computer" choose administer, choose disk handling, here you see the same disks, but now a bit smaller.
This size is you actual space.
regards
/Teis -> Vote, Please
  • Anonymous Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
1helpful
Which is smaller, gigabytes or megabytes
megabits is smaller
if you want to back up 2.83 gb get a usb flash drive
get a 5gb unit
usb sticks (flash drive) rated at 5 gb will hold 4.5 gb of data as the rating is the total capacity but all flash drives require a small amount of space to work so the actual amount of data capacity is always less than the stated size on the flash drive
the capacity rating is-- smallest to largest --bytes, mega bytes , gigabytes, and terabytes
Try figure out the right hard drive for this
You have to different types of hard drives, sense you gave little info, here goes. the older pc's had an ide harddrive, you look at the top of it there is 30, or 40 something pins to plugin. the newer pc's laptops came out with an ''sata hard drive! there are two plugin types on these, they done away with the pins. Each hard drive has different storage, look at the front of it, the size of storage will be there. it will say something like this. 120Gb, 500GB, 1Tb. 2Tb'' The size will be Gb, gigabyte or Tb terabyte. Hope this helps!
Lost USB cable for wd12008015
Generally speaking the cable is a regular connection that goes to the computer and a USB micro connection that goes to the hard drive. This would apply to enclosures using a 2.5" laptop drive.
It would be a regular USB connection and a USB 'B' connector if the enclosure uses a 3.5" full size hard drive.
3answers
I have a datatraveler 4gb stick how many photo will it hold
That is not exactly to calculate. It depends on the stored image sizeand quality.
Small pictures could be 400KB a piece, but large ones easily can go up to 6GB
a piece. If you know thye avaerage size of your pictures, you can calculate it.
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
2answers
HardDisk
Just continue in formatting the hard drive because this can be cause by some malware that's why your hard drive is just showing that size and after you format it everything will be clean, the other reason why the hard drive is just shwoing that small size even though its a big size there's a possibility of bad sector on the hard drive so don't use the quick format when you reformat the drive so the bad sector will be fix also...
Question on the Compaq Presario 700
You can find the hard drive size by opening my computer and highlighting the C drive (this is basically the hard drive), towards the lower left of the screen it will tell you the initial size and how many gigs you have left. If it says something like 38.6 g, then it's a 40g hard drive (hard drives are in even sizes, so, round up), the missing 1.4g is used for drivers and utilities. This is just an example, I don't know exactly what size yours is, they come from the factory with various sizes. The optical drive is the CD drive. So, is it a CD-ROM, CD-RW, DVD-ROM, DVD+RW. It will say on the front of the drive what it is exactly.
Hard drive compatibility
This motherboard is compatible with PATA/IDE Hd's running at 133/66/33Mbs. & ATA/SATA 1.5Mbs drives. The SATA's run faster. This board will not handle a SATA II's speed but it will still run on the P5P800-VM board. The links below show good buy's on both PATA/IDE & SATA I & II. Seagates for their 5yr. warranty.
Seagate ST3160215AS 160GB ATA/SATA
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117012
Seagate ST3160215A 160GB Ultra ATA/100
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117010
As far a size, that is up too you. Windows can handle 5 time these sizes.
Please don't forget to vote.....
Copy memory on HP L7580
sounds like you need to change your virtual memory settings or buy more RAM.
Here is how to change the settings:
I am assuming you use WINXP
  1. Click Start , right-click My Computer , and then click Properties .
  2. Click the Advanced tab.
  3. In the Performance section, click Settings .
  4. Click the Advanced tab.
  5. In the Virtual memory section, click Change . Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be about 200 MB, and should be higher than or equal to the recommended paging file size shown in the lower section of the dialog box. When you set the initial size, Windows reserves on the hard disk drive the amount of space you designated for virtual memory. The maximum amount allowable can be anything above the Initial size setting, but it should be at least twice the Initial size setting, as shown in Figure 2. Figure 2: The Windows XP Virtual Memory settings c00174885.gif
  6. Based on the information above, make any necessary changes to the Initial size and Maximum size settings.
  7. Click Set , and then click OK .
Grand Canyon Tech
Grand Canyon Tech
