Hi my printer epson r1800 is blinking two red lights and the message end of service life appears ,can i fix this problem thanks kelly
Sponsored Links
Same Problem
Mar 22, 2009
-   I have the same "blinking lights" waste ink pad counter problem. I've installed the InkRepublic waste ink bottle and tubes system and I've downloaded and tried to run the Reset Utility from Epson _BUT - with no success. That reset utility says it cannot find a supported printer.
I've also heard of a "button hold combination" that might work - but I've not been able to locate that yet.
-   i have the same problem and cannot access the cartridges as the printer head will not move i tried therecommended download but it wont do anything for my printer-   the blak hat
1. The SSC utility mentioned by Jacklee366 is usually the first port of call but it may not work in some situations. Worth trying regardless
2. Epson have an official reset utility which is available to North American printer owners who have a valid serial number (back of your printer). You just fill out this form and you will then get access to the utility (the one eagleflh/bos_dsl is reselling with his kits)
3. You can also get access to the official service utility that service engineers use on these printers... A copy is available here. IMPORTANT: This utility is a lot more powerful than the other two and requires a bit more hoop jumping but it can resolve the maintenance request very efficiently. Whatever you do, read the readme files and take your time if you opt to use it.
Hope that helps.
Comments:
Feb 22, 2009
- Oops... my mistake.. The epson reset utility link is missing in my solution above... The link is here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I spent a lot of hours and a few days trying to solve
this.The only thing that finally worked
for me was the Adjustment Program from 2manuals.com.
I purchased it (less than $10.00), downloaded it to my PC
(no Mac available), unzipped the program, tried it a couple times with no
success –
it gave me a communication error –
so I changed my printer cable (from Firewire) to UBS cable and changed the port –
Once past the communication error I selected the “Particular Adjustment Mode”,
then “Auto Selection” in the Setting Port Selection window,
double clicked on “Waste Ink Pad Counter”,
clicked on “Get Status”.
It will tell you the value reading on your printer.
Click on “Initialization”
and – WAM BAM – you’re done.
Really – I spent about 8 hours over the last 3 days trying
to get this done.
Don’t be put off by the awkward payment process at 2manuals…I had googled them and read a bad review –
but, desperate as I was, I tried it anyway and I had NO problems.
i got the SSC utility too work that time an all is well now the head wouldnt clean but used a syringe of hot water a few times with plex pipe to connect to the nipple that fits into the catridge and when i had completed a few runs of water i then removed the liquid by putting the flex pipe down to the base in the area left of the head and removed the gunk in there hope this info helps some one
How do i take the m/c apart to get at the Waste Ink pads to clean them after getting the warning...
(More)
How do i take the m/c apart to get at the Waste Ink pads to clean them after getting the warning -some parts have reached the end of their life. I have followed your resetting guide with success-many thanks so now need to replace or wash the pads to complete the task--can u help please
My Epson Stylus Photo R1800 is non-responsive. When I turn it on, the paper-jam and ink buttons...
(More)
My Epson Stylus Photo R1800 is non-responsive. When I turn it on, the paper-jam and ink buttons flash red, but they don't do anything when I push them. I think he's having a seizure;(
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a...
(More)
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
