Question about Kitchen Ranges
My tappan oven will not always light
My Tappan oven model is 30-2538-00. It is about 10 years old. Most of the time the igniters will light the burners for the stovetop and the oven, but occasionally they will not--not any burner or the oven. The igniters are clicking (as we can hear them for the stovetop--we never hear them for the oven). What might be the problem?
    Habit-Forming:
  • 171 Answers
For the top burners you have to get to see the ignitors so that you can see the spark,the spark have to spark like a spark plug in the car, it most be on the tip of the ignitor.if not. the spark it's sparking on the wroung spot,wires may be wet or broken. thats one of the reason, the second one,there is small holes fasing the spark ignition on the burners when grease blocks them, they will not light, you can clean them with a paper clip or a safety pin. for the oven,some ovens do not have the spark sistem, they have the ignitor wich it looks like a small bar about 4 inches long by 1 inch some of them are round. thats the part that needs replacing
Posted on Dec 11, 2008
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
I have a Tappan Electronic Ignition gas range. It is 20 years old, I cannot find a model number on it. The oven will not light, but the top burners still work. The problem with the oven has happened before...
You most likey have a bottom ignitor out. It will not work with out a new one and you can get theses online. You can take off the ignitor and see if there is a number on it.
Nov 02, 2010 | Tappan Kitchen Ranges
Hi, I own a Tappan oven..model #TGF364ASF..the
Hi an welcome to FixYa. I am Kelly.
If nothing lights... i.e burner or oven there are only 2 things that can cause this problem. A failed ignition module or a wiring problem. The wiring problem can be a simple short or a broken power lead. All of the stove top ignitors are in a series parallel connection and if one of the burmer control shorts you loose the stove top. With nothing is lighting oven and burners it sure points toward the ignition module or power to the module.
Thanks for using FixYa.
Kelly
Note... The ignition module itself is not cheap.
Apr 09, 2010 | Tappan TGF364AS Gas Kitchen Range
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Sep 24, 2008 | Tappan TGF657 Gas Kitchen Range
Oven temp off
You either have a plug up in your flame from dirt etc.
or your valve needs to be replaced.
Try turning off the gas and getting to the burner and clean it first.
Mar 22, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
208 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
