Question about E-Machines eMachines Desktop PC
Replacing CMOS battery
I replaced my CMOS battery, what must i do next?
    Genius:
  • 1,061 Answers
See if computer will reboot as normal. If not shutdown and go into the bios and find the default/setup settings and turn on. then reboot.If you have a problem still. Contact me here with motherboard type and what os you are running. I hope this has been helpful RICHARDM69
Posted on Dec 06, 2008
Toshiba a205 s7466 will not turn on replaced cmos battery what next?
use old battery first try to boot
if your system is boot run bios update from intel.com
then change new battery
else run bios flash from chip level service provider
Feb 14, 2014 | Toshiba Satellite A205-S4617 Notebook
Tip
How to verify that the CMOS battery needs to replace
<p>The CMOS battery is named after the Complementary Metal Oxide Semiconductor power. The CMOS has the current date and time functions for desktop and laptop computers. It allows the computer to automatically adjust the time, even on computers that are disconnected for long time. When a computer no longer has the date and time and forget it on every boot, the CMOS battery probably needs replacing. Some computers have messages when the battery is weak, while others just lose the current date and time after each shutdown.<br /> <p>Time & Date Errors<span> </span><br /> <p><span> </span><br /> <p>1. Turn on the computer. Look in the task bar at the bottom right. Make sure the date and time is set correctly. Double-click the time and click the up or down arrow to switch to the correct time. Click on the arrow next to month to change the month. Click "OK" when finished.<br /> <p><br /> <p>2. Turn off the computer. Wait 3 to 5 minutes and start the machine.<br /> <p><br /> <p>3. Look on the taskbar to see if time was lost and said a strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br /> <p><br /> <p>CMOS Error Message<br /> <p>1. Look for error messages like "CMOS checksum error", "CMOS Read Error" or "CMOS battery failure" when you start your computer. These errors are caused in the machines shut down for several months or when the CMOS must be replaced.<br /> <p><br /> <p>2. Let the computer on for 24 hours. Restart the computer and find the error.<br /> <p><br /> <p>3. Change the CMOS as the return error.<br />
on Jun 21, 2011 | Computers & Internet
Clock problem when i open the system
If the Date & Time changes back to some previous date when you next boot up the computer then the CMOS battery is worn out and needs to be replaced. After replacing the CMOS battery go into the BIOS and set the Date 7 Time.
Feb 22, 2013 | Asrock 4CoreDual-SATA2 Motherboard
Need to replace cmos battery in Gateway MP8708
Power down PC. Open the PC tower. Look at the motherboard and find the CMOS battery. Looks like the picture below. Make sure you touch some sort of metal area on the PC to ground yourself before touching the components. Use something thin to pop the old CMOS battery out. The CMOS batteries are usually universal. CR2032 is the usual type used. These can be found at a CVS or Walgreens. Once you have acquired the next battery, make sure the CR2032 is facing up and just press it in.
-Ben P.
Dec 31, 2012 | Gateway Computers & Internet
CMOS location in gateway model # 6332
The CMOS battery on the Gateway M-6332 is located either next to or underneath the WiFi card. With the laptop upside down, loosen the three screws along the rear edge of the panel next to the fromt of the laptop. Remove the panel and you'll see the hard drive and the WiFi card. There will be one or two Mini PCI Express slots. I've replaced the mainboard in this one, don't recall if the original only had one slot, the one I installed has two.
That's where the CMOS battery is, held to the board with a piece of double sided tape and connected by a pair of wires to a small plug.
Jan 21, 2012 | Gateway Computers & Internet
The battery charge light shows green, but the screen is black and no boot. How do I get to the CMOS battery? THANKS.
Hi cqs2000.
Do the following:
"To "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}.
  • paul7of9_182.jpg Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
paul7of9_181.jpg Replace the "CMOS battery."
  • Next, "Only plug-in the "Power Adapter" into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!"
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 15, 2011 | HP Pavilion xh485 Notebook
HP Compaq NC6000\r\nWhen I press the power button it seems to start but the only thing I see is numbers going by rapidly in the form of kbytes (524288 KB ok) then it reads 162-system Options not set. Then...
Hi promano67
When you "start" the computer, and the {"Screen"} displays a "Error Message."[CMOS] "error checksum!"
Settings: "Default" loaded.A "checksum error" shows that:
The ("Boot-up Settings "have been changed?"), ie. "Booting OS."
*Boot File 'missing'.
"This can 'occur' if the computer was "shut-down unexpectedly."
Force Shut-down : Power lost; due to 'low battery...'
A ("Power Surge") can cause this 'problem' also.
"What 'happens is that the [CMOS] settings are lost!".
"To fix the problem!"
Do the following:
  • "Restart / Boot the computer.
  • Next, verify if the 'error message' displays?
  • If you are still getting the message?
  • "You will have to "Remove the CMOS battery form the computer!"
  • "You will need a {very small Phillips screwdriver}._953.jpg *Remove the CMOS battery for: [30 minutes].
  • Replace the "CMOS battery."
  • Next, "Only plug the Power Adapter into the computer.
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" _951.jpg
Mar 13, 2011 | HP Compaq nc6000 Notebook
Having trouble having to reset the date each time I start the puter. I've replaced the battery twice in the last 3 weeks so that's not the problem. I keep getting CMOS error. Help?
pop out your battery and replace it with a new one and reset your bios by changing the jumper to the next position that is covering pin 2 and 3.... and set the time in cmos...... you are there.... pls vote if you like this solution.....
Jun 16, 2010 | EliteGroup K7S5A Pro Motherboard
Always display bad cmos setup
have you checked the jumper next to the cmos battery? check if its good not broken and also try and upgrade your firmware. visit your motherboard's manafacture for the firmware upgrade.
Nov 13, 2008 | Asrock P4I45GV R5 Motherboard
E-Machines eMachines Desktop PC Logo
62 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
