Question about Dell Dimension 2400 PC Desktop
Dell monitor dialog box says monitor is in the power save mode
It says to activate using PC. I cannot get the monitor to come out of this power save mode. I have a black screen with ony a small dialog box stating that the monitor is in the power save mode - activate using PC
  • Linbusy Jan 06, 2009
    When I turn on the PC, sounds like it's starting up just fine, but monitor is black. When I hit some of the buttons on the front of the monitor, a message about being in PowerSave mode is on the monitor - and it tells me to hit any key or move the mouse, which doesn't work. After a couple of seconds, message disappears and screen goes to black.
    I turned everything off, redid connections, held cpu on button for 10 seconds then restarted. No changes.
    When I unhooked monitor from cpu, monitor showed self test box with the different colors.
    When I plugged in an OLD Dell Monitor, screen stayed black when it was hooked to cpu, but when disconnected, got a message on now disconnected monitor that there was no signal.
    Is this the cpu? video card?
    Ideas?
Actually, it most likely is not the monitor which is in "power save mode", it is the computer itself.
When you cannot get a computer out of "power save mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty.
Usually, this happens on a computer which is a few years old, since its batteries will have run out after such a long time. (The motherboard battery is used to store various settings when the computer power is off, such as date and time. When your computer detects this battery is empty, it goes into a low-power mode).
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Posted on Dec 07, 2008
  • theresay Jan 12, 2011
    Saved my life!!!
  • 3,940 Answers
This error normally occurs when the monitor is not receiving a singanl from the tower. So 1st check the cable connection to the VGA port on the back of the tower and ensure that the cable is securely connected. While looking at the back of the tower, look at the diagnotic LEDs near the PS2 ports marked ABCD. They should all be green If they are not, then there is a problem with the tower and you need to post the indications on the LED (GGAA for example indicates a RAM failure)
If you are using an LCD monitor, you may also need to check the input select button on the monitor if you accidently bump or press the button, then you could change in input selection to DVI and then get this error too.
Posted on Dec 06, 2008
4 Suggested Answers
joelmar
  • 96 Answers
SOURCE: Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
Posted on Jun 08, 2008
ebay312
  • 118 Answers
SOURCE: Dell PC Power Save Mode
When you first plug it in and turn it on, the monitor will shut itself down with only this little note until it receives a signal from the computer to do something else.
You will have to double check the computer as well, and ensure that it too, is turned on. If this is the case, then your next step is to ensure that the monitor and the computer are talking with each other, that is, you'll have to unplug the monitor from the computer and plug it back in again.
If you do all these things, and you still have this message, then something may be wrong with your video card. At that point, you may have to consider taking it to a professional.
good luck
tony
Posted on May 19, 2009
  • 131 Answers
SOURCE: Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Posted on Apr 23, 2010
Testimonial: "Will try when the monitor does this again. Was very helpful. Thanks!"
My dell monitor is on power saving mode I am using the monitor with cameras so do not have a pc I cant turn the saving power mode off
Without a PC you have no control over the power saving mode. You can't turn it off without one, that comes right from Dell.
Nov 20, 2016 | Dell Computers & Internet
How do I take my monitor off power save mode?
You Will Have To Look That Up In The Manuals For
The PC, Video Card, Monitor
And Uese Google To Look For And Donload These Doccuments!
Oct 10, 2014 | Dell Computers & Internet
Dell Pc won't boot gets black screen with floating dialog box
Floating dialog box is the monitor's self test. Your monitor tests good. Your computer is the problem.
Mar 04, 2013 | Dell Dimension 3100 PC Desktop
FPD1930 gateway monitor powers up then a small box saying power save mode appears then it just goes black what's wrong with it
Hi. power save mode being displayed by the monitor could be caused by 3 things.
1)VGA cable to monitor is unplugged - check connections at computer and monitor
2)video card has been partially dislodged from motherboard socket. -remove computer cover and ensure video card is firmly pushed down into motherboard socket - do not use excessive force.
3)Monitor does not support video settings on the computer. - to fix on PC, turn on computer and press F8 button a few times during bootup - Windows will go to bootup screen - select SAFE MODE and hit enter. follow onscreen instructions - dont worry about weird colours and huge desktop icons - this is simply to get you going. Right click on desktop, select PROPERTIES>SETTINGS TAB. select screen resolution 1024*768 0r lower, select Apply or Ok. Now restart your machine
Dec 08, 2012 | Computers & Internet
I have an old Dell computer monitor that is hibernating and can't be waked up. When I try to wake it, I get an Information Box that says "Monitor is in Power Save Mode. Activate by using the...
click the mouse, move it about or press a key , if that doesn't wake the pc up, then press the power button for 1 sec, that will wake it up
Apr 14, 2011 | Dell Computers & Internet
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Cheers
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
Before Windows can boot-up the screen turns solid blue & a Dialog Box state "Entering Power Saving Mode". The screen then appears that the sleeping mode has occurred.
just switch off and switch on the monitor or press any button on keyboard to bring monitor from power saving mode thats all
Sep 23, 2010 | Dell E207WFP LCD Monitor
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
My monitor has the below message. How do I fix
If your monitor is correctly connected to your pc it will activate when you perform any action on the pc
Check the connection with the pc - plugs at both ends inserted correctly?
If that does not work, try connecting a different monitor, if you can. If that works it is a hardware problem with your monitor. If another monitor does not work, it is a problem with your pc (video output or graphics card)
Feb 16, 2010 | Dell M992 Monitor
Dell Dimension 2400 PC Desktop Logo
1,754 people viewed this question
Alun Cox
