Question about Denon DVD-9000 DVD Player
Denon 9000 has problems reading dvd discs.  Plays fine for an hour or so then skips.  changing discs does not help.  Must let system cool down and start over
  • 88 Answers
SOURCE: denon 9000 skips after an hour of use
it sounds like you have a heat problem,try to put your player somewhere that it has alot of room to keep cool,i've noticed some people put there players on top of the t.v. or close to other electronics,the whole key is keeping things cool,let me know if this helps because you have a very good player.
Posted on Dec 06, 2008
Denon dvd 1730 plays no cds
It is likely a issue with the optical pickup in the unit or the unit needs cleaning (not likely but possible)
Apr 08, 2012 | Televison & Video
Trouble reading discs
Well compressed air is ok to a certain extent. But sounds like you need one on one with laser. Open up and clean with soft cloth and alcohol, I found the best way to do it. let dry and try again. Hope this helps
Sep 07, 2007 | Denon DVD-9000 DVD Player
My denon dvd player plays for about 30 seconds then starts over <can anyone help
purchase a dvd lazer cleaning disc from your local electronics supply compant and run it through the player several times this will fix the problem so long as the lazer is not fully burned out
best of luck
Nov 30, 2010 | Denon DVM-1805 DVD Player
Dvd player makes noise, doesn't read discs
mine did the same thing it just kept ticking when i wanted to play a disk, id take to top off with the four tiny little screws and hoover it, mine still makes a bit of noise but works x
Mar 11, 2009 | Panasonic DVD-F86 Multi-disc DVD Player
Dvd playback
Clean the DVD lens with isopropyl alcohol (rubbing alcohol) and a Qtip. Be careful not to press down too hard. Gently clean the lens all around. Changing Qtips if you see anty signs of debris or dirt on the tip.
Feb 06, 2009 | LG RC199H DVD Recorder/VCR
DVD player: all disks freeze or skip at same point.
with some models it's very sensitive to being level. try moving your dvd player to a common flat area. see if it's a little rocky or placing a single piece of paper under one of the corners...I had a dvd player that would freeze on every disc and since I moved it to the botton of the cable box it no longer locks up. Worth a try.
Jan 04, 2009 | Denon DVD-800 DVD Player
Denon 9000 skips after an hour of use
Dec 06, 2008 | Denon DVD-9000 DVD Player
I just doesn't load/read CD's.
I had the same problems with my four year Denon DVD-3910 and the only solution to it was to replace the laser unit with a new one.
There are some repair service on EBay that offer new laser units for only about 50 € and are also willing to change the laser unit for an extra charge of just 30 €.
After this replacement your Denon DVD-3910 will work fine again.
Sep 10, 2008 | Denon DVD-3910 DVD Player
Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
Denon DVD-9000 DVD Player Logo
65 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
