Question about Garmin StreetPilot c550 GPS Receiver
Is there a way to reset a garmin c550
Can I reset a garmin c550, or do I have to let the battery die?
  • ej20sack Feb 05, 2009
    my garmin is stuck in the wrong city and wouldn't change even after i enter a new address.no matter what i try it telling me i'm on i80west when i sitting in my house how do i rest set the garmin street pilot c550
Http://www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf page 29 & page 30 discuss the 2 options for reset/restore.. one clears all saved data (i.e. favorites) & the other resets the system. I'd also suggest connecting the usb cord to ur pc & GPS , then use the update software, This can resolve any issues you may be experiencing.
Posted on Jan 17, 2009
3 Suggested Answers
namzyanzy
  • 435 Answers
SOURCE: how do i reset the c550
To perform a master reset on the StreetPilot c5xx series:
1. Power the StreetPilot off (ensure that it is not connected to external power)
2. Touch-and-hold your finger in the lower right corner of the Touchscreen
3. Power the StreetPilot on
4. Continue to hold your finger there until "Erase all user date?" appears
5. Remover finger from the Touchscreen
6. Touch "Yes"
Please rate the solution....
Thank you
Posted on Nov 14, 2008
  • 373 Answers
SOURCE: garmin c550 battery replace
Check on garmin.com
Posted on Feb 04, 2009
Forgotten my pin number for garmin and my secret location. how can i access/reset it please?
Welcome to FixYa!
Here's how to reset Garmin Street Pilot C550:
1. Remove the front plate of the c550 by sliding your finger under the groove in the plate below the Garmin mark on the plate.
2. Push the now-exposed reset button. The reset button is located on the same side of the c550 as the power cable connector.
3. Plug the c550 into an external power source to restart the c550 after you have reset it. The factory default settings will be restored.
Thank you for using FixYa.
Have a great day.
Jas247
Apr 26, 2011 | Garmin StreetPilot c550 GPS Receiver
GARMIN C550
Hi Don,
You probably just need to find the reciept where you bought the C550.  Sounds like Garmin is protecting its customers when they say $300.  This is most unfortunate thing to happen to you.  Is the Garmin $300 issue as I thought and related to you not having the registration code or Reciept?
Oct 13, 2007 | Garmin StreetPilot c550 GPS Receiver
Will not turn on
It is possible that the internal battery has discharged, and is unable to recharge due to a blown fuse inside the cigar lighter plug or a blown fuse in the car's fuse block for the cigar lighter outlet.
  1. Unscrew and remove the silver or black, round end piece.
  2. fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e53bea0-6874-11dd-436f-000000000000%7d&ext=jpg
  3. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  4. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e476290-6874-11dd-436f-000000000000%7d&ext=jpg
Consult your car's owner's manual for locating the fuse block in the car. Both fuses must be good.
If you're unable to power up the c500 outside of the car (running on internal battery) your c550's internal battery may no longer be able to accept a charge. This will require a battery replacement - or use with a cigar adapter only. You may have to return the GPS to Garmin for a battery replacement - but there are some third party battery providers for some Garmin GPS units. If one is available for the c550, you may save enough money to make going the third party route worthwhile.
Please rate this replay if helpful - good luck!
You can download / view a copy of your c550 manual here.
Aug 09, 2010 | Garmin StreetPilot c550 GPS Receiver
Will not charge c550 garmin
OK, THANKS, THE MOST LIKELY PROBLEM HERE IS THE BATTERY IS DEFECTIVE.
Nov 11, 2009 | Garmin StreetPilot c550 GPS Receiver
My Garmin c550 just stopped working today. It is about 3 yrs old. If it is a battery, how can I get it replaced? I'm in Orlando, Fl
Mine did the same. Wouldn't power on. The manual says if it doesnt power on when plugged into a power source, reset it.
There is a groove on the faceplate under the Garmin logo. place your thumbnail there and gently pry off the face plate. Look for the reset button on the right side, press it.
The unit should power on for normal use.
http://www8.garmin.com/manuals/StreetPilotc550_OwnersManual.pdf
If you need to re-set it often, update the system software.
Feb 19, 2009 | Garmin StreetPilot c550 GPS Receiver
Dead Garmin c550
had same exact problem. my unit would come on for a minute and then go black. if you take the silver ring around the face you will see the four screws to take the unit apart if you do have to replace the battery. however first try hitting the reset button on the right side of the unit. remember the cover needs to be off. i hit the reset and my unit powered on with no problems
Oct 31, 2008 | Garmin StreetPilot c550 GPS Receiver
Forgot pin number
The only way to unlock a PIN locked Garmin is to enter the correct PIN number, or take the unit to the location at which the PIN was entered. Your only other option is to send the unit to Garmin.
Jul 16, 2008 | Garmin StreetPilot c550 GPS Receiver
GARMIN C550
hey u got to try 4 digit.. try to do it the most you cant and belive me u will unlock your garmin c550...after felling alot of times will go back to reset and it will unlock..good luck
Feb 26, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin C550
Remove the front faceplate, (there is an indentation under the word Garmin on the faceplate that you can use to lift it with your finger nail). After removing the faceplate you will see a reset button on the right side. Press the reset and then try to turn the Garmin on.
Jan 30, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
1,861 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
