Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
TV ON AFTER TV OFF WAIT A VERY LONG WILE TO TURN IT BACK ON
TV TURNS ON AFTER A LONG WHILE OFF AFTER IS ON U TURN IT OFF AND IT HAS TO BE DISCONECTED FROM POWER OUTLET AND WAIT A LONG WILE TO TURN IT BACK ON
    Scholar:
  • 87 Answers
You have a bad SSB module cost of part is about $280.00
Posted on Jan 12, 2009
Magnavox tv lcd 47" wont turn on it, use to have unplug from the wall wait a wile then it would turn on ,now it wont turn on anymore
I don't have a model number,but am willing to tell you that this is a classic problem. Magnavox LCD TVs have had bad capacitors that will prevent them from starting up and staying on. Thanks for asking and show a few hands of support!
Oct 07, 2010 | Philips Televison & Video
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
Tip
I hope that helps.
on Apr 06, 2010 | RCA RCR311B Remote Control
Door was opened at beginning of self cleaning sequence.. locking mech is still stuck
hold button for light down and hold it wile pushing put in clean and wait till it starts then push stop or cancel and wait til cleared dont let go of light switch till done.if don't work have someone hold down the switch wile you turn off the breaker for 2 min
Dec 24, 2009 | Frigidaire Ovens
Tv use to turn off wile watching now will not turn on
I have a magnavox 31' CRT that did that to me. Turns out the power button on the TV gets stuck and so the slightest vibration of somebody walking past (wood floors) would cause it to power on or off. It would also keep the remote control from working until someone tapped the switch to un-stick it. Small problem considering the TV is 18 years old and still looking good.
Aug 15, 2009 | GE 31GT659 31" TV
No picture just sound
ur xbox 360 is in high def turn ur xox 360 with ur controller and hold r trigger and y button together till it turns on. if it dont work than u got the rings of death try this there are fans in the back of ur xbox 360 put a straw on each to stop the fans from spinning wait till it has two red lights than disconected from the back and wait 20 minutes and try it see if it work. if it work this is just a temperary fix.
Jul 02, 2009 | Microsoft Xbox 360 Elite Console
Sharp Aquos lc32
try unpluging for wile then back in unplug everthing from it totest then back in one ata tiem if not bad board these sharps 32 knows for it my dad has one also made him buy 3 yr warenty on this all over online these know for having board issues getting hot ok
Feb 10, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
