Question about RCA P60920BL 60" Rear Projection Television
I just purchased a used RCA P60920BL 60 in. Rear Projection Television. It worked for the first 3 days and then just went black and started making a chirping sound. I read a bit online and seemed to be the flyback so I purchased one and took the old one out and installed the new one. I am still getting the chirping sound. Any ideas??
  • quadrider247 Dec 13, 2008
    I took the tv to a repair shop they said it was the horz output, power supply, and HV transformer. I found the horz output and the power supply but cant find the HV transformer on the schematic, would it maybe be called something else.
  • 106 Answers
Right in front of the flyback, on a metal heatsink, you will see a transistor. This is the Horizontal out transistor ans is probably shorted. Look at number on the front of the transistor for ordering. It will be 2SC5148, 2SD1878, or something like that.
Make sure the unit is unplugged while working on it
Posted on Dec 06, 2008
  • tvguy171
    tvguy171 Dec 13, 2008
    The HV transformer is the flyback. If I am not mistaken, you said you already replaced that. If you put the horizontal out transisitor in, you problem should be fixed. The flyback goes bad and shorts out the horizontal output transistor. I can't tell you how many of these sets I have fixed. Please rate this and let me know if I can be of further assistance
60 ic7410
Just visit this link It has details about convergence procedure to rear projection television. Convergence adjustment procedure to most brands PTVs will be similar. Pull up older posts there, by its left side bar. http://electronicshelponline.blogspot.com/
May 30, 2013 | RCA P60920BL 60" Rear Projection...
Want power up but is making a beeping noise
The beeping is usually caused by the Flyback transformer and HOT transistor. You can get the 239111 flyback and HOT repair kit from www.tvrepairworld.com
Nov 23, 2011 | RCA P60920BL 60" Rear Projection...
The colors are separating
If you haven't used the autoconvegence option in the menu screen try that. If not clean the projection lenses inside the TV with qtips and alchohol with the tv on so you can see if the lenses are clean.
Mar 08, 2010 | RCA P60920BL 60" Rear Projection...
Rca P60920BL starts steady chirping when plugged in
This is usually the flyback transformer (IHVT-integrated high voltage transformer) and the HOT( horizontal output transistor) The transistor will read shorted, with a multimeter, if it is bad. It is mounted to a heatsink straight back from the flyback. It may have a metal clip that holds it tight to the heatsink.
It is a pretty easy fix if you can solder.
While you have the board out, check for any discolored resistors and replace those as they will likely fail before long and cause more problems. Also check with a bright light and a magnifier for cracked solder joints and resolder any that you find.
Jan 20, 2010 | RCA P60920BL 60" Rear Projection...
RCA P60920BL wont power up makes clicking sound
This is a chassis PTK195 and acommon fault with these sets, that causes the symptom you describe, is the flyback transformer goes bad.
If you're at all familiar with electronic repair you could start checking there (and horizontal output transistor shorts). If not have an RCA approved warrany repairer give you an estimate/service call.
Note: the good thing about these sets is the chassis is very common and easily removed for service (without bringing in the whole set.) .
Usual cost to repair flyback/ dead set symptoms $200-$350.
Nov 24, 2009 | RCA P60920BL 60" Rear Projection...
RCA rear projection 60in powers off
you need a new light bulb. buy one on ebay for cheap and replace and it will work just as if the tv is new
Feb 10, 2009 | RCA P60920BL 60" Rear Projection...
Black screen and chirping sound
Typically, the driver circuit is affected when the flyback transformer "dies". The most common device that fails with it is the deflection transistor/driver and associated components. Hope this helps...accordianman
Dec 06, 2008 | RCA P60920BL 60" Rear Projection...
Chassis
And what was the symptom of what your set was doing?
Mar 04, 2008 | RCA P60920BL 60" Rear Projection...
P60920BL beeps at me.
Sounds like you have a flyback transformer and horz output bad,the beep is because the output is shorted
Feb 22, 2008 | RCA P60920BL 60" Rear Projection...
Rca
1)Any power indication?
2)Please provide service # and chassis # from back of set .
3)Then we will get you a sggestion.
Oct 15, 2007 | RCA P60920BL 60" Rear Projection...
Televison & Video Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
