Question about XM Radio (XMP6000)
LCD SCREEN IS REAL DIM
I HAVE AN AUDIOVOX MODEL XR9 I WOULD LIKE TO KNOW IF THIS PROBLEM CAN BE REPAIRED?
    Genius:
  • 1,239 Answers
HI The backplane lamps, and or the backplane power supply is probably starting to fail. This is common in LCD sets.
In some models, the backplane parts are replaceable. In other's the complete display has to be changed.
Call the factory service rep in your area to arrange to send them the set for an estimate to service it.
Posted on Dec 06, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 06, 2008
    IF IT IS NOT THEN Just want to let you know that the problem you are having is a bad X board.
    THANK YOU...........
    Sergeant:
    Champion:
  • 304 Answers
Yes it can be repaired. could be a replacement on the display if no corrections was needed/.
  • 13,433 Answers
Yes it can certainly be repaired, the problem is most likely on the LCD screen or its backlight, if it problem is the lcd screen or its backlight you may be able to replace the backlight or you might need to replace the whole lcd screen, but note that the problem may also be on the sourse / the controller of the lcd display or the main board on the radio some components may be failing possibly capasitors leaking or failing it needs to be looked at, can't say over the internet.
Screen is real dim, but I can see if use another monitor
The back light might have failed. You will need to have tis repaired if you cant do it yourself.
Nov 03, 2012 | Gateway C-140 C-140S C-140X C-140XL M280
Jensen 9314 lcd repair. Can this be done. the screen got damaged the outer screen is ok but it looks like it shattered internally, a very small part of the screen shows
It can probably be repaired, but you will more than likely have to send it to Audiovox to get it repaired. Audiovox owns Jensen. You can get a hold of them at audiovox.com.
Aug 15, 2011 | Jensen VM9314 Car Video Player
My screen is real dim I can't see anything unless I put it direct sunlight what the problem
It sounds like it is a backlight problem on the LCD Screen. You will have to get it repaired by a qualified technician or return it under warranty.
Apr 24, 2011 | Absolute Avh6000 Car Video Player
Sony LCD TV has Dark Picture
the problem is not the lamp.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
May 30, 2009 | Audiovox D1210 Portable DVD Player with...
The screen on my Audiovox FP1510 has gone dark
Yes, there are 4 backlight lamps but it seems you have a problem with the circuit, called inverter, that controls those lamps. m@nt
Mar 15, 2009 | Audiovox FP1520 15 in. LCD Television
Dim picture
change ur backlight ccfl lamp
Oct 19, 2008 | Audiovox FP1520 15 in. LCD Television
Audiovox D1812 disc loads & plays but VERY dim screen
Sounds like the backlight isn't working, could be the flourescent tube or the inverter that powers it. At least those are the likely suspects in other LCD monitors that have similar problems.
Apr 01, 2008 | Audiovox D1812 Portable DVD Player
Fatal error, unable to open application database
Have you tried the reset button? It would be found on the lower right side on the rear panel. Don't really know if this will fix your particular problem, but it might be worth a shot.
Dec 13, 2007 | Audiovox NVX226 GPS Receiver
AUDIOVOX D2011 - SCREEN IS BROKEN / WHERE CAN I GET IT REPAIRED?
Look on ebay, if you still see the video, then it is just the backlight that is broken. Put in your model and add the word parts to your search. Be sure to read if the parts one you are buying has a working backlight.
Oct 10, 2007 | Audiovox D2011 Portable DVD Player with...
AUDIOVOX VE1020 has audio, but no video
Ok, here is a bizarro solution that just worked for me. It is a solution to the problem, not a technical fix.
1 Turn unit on
2 Using remote control unit press "DVD" button, upper left.
(When I did this the Audiovox screen appeared)
3 Then using remote control unit press "TV" button, upper left next to DVD button.
(For my unit, this gave me a TV picture)
Strange, huh?
Dec 14, 2006 | Audiovox VE1020 10.2 in. TV/DVD Combo
Car Audio & Video Logo
26 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
