HAVE A NATURAL GAS FURNACE. PILOT KEEPS SHUTTING OFF. REPLACED THE THERMO COUPLER AND CLEANED ORAFICE BUT STILL KEEPS GOING OUT. ANY SUGGESTIONS? THANK YOU
  • 85 Answers
Did you adjust the therm coupler to the flame correctly, even a little bit off can keep the pilot from sustaining.
Posted on Dec 06, 2008
How do I bypass my hayward h250 millivolt pilot light
cannot check pilot generator, then make sure no cobwebs in tube or assemby if dirty clean if clean replace thermo coupler
Jun 25, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot won't light
There is a remote possibility that the replacement thermocouple is defective.
Nov 17, 2013 | Heating & Cooling
Coleman evcon furnace
Did you clean the pilot orfice?? It has a very small opening about the size of a hair. You may have to use a needle to open the opening....Are you getting gas to the pilot orfice assembly from the Gas Valve when you set it to Pilot?? If not then check the pilot adjustment screw on top of the gas valve at the pilot tube. CW decreases flow.
Coleman h 90 gas furnace will not start up when thermostat is turned up
The gas valve is not lifting hence no gas flow , check pressure switch if fitted jump out thermostat see if it lights ,
Jan 10, 2013 | Heating & Cooling
The pilot lite in my sears 10 natural gas furnace model 867764510 will ignite but go out a short time later.
simply replace the the thermo couple. Any home depot. Very easy.Be sure all doors are in place or it could cause the flame to pull away from the thermocouple. If the problems new, change it. 5 minutes literally. Shut off gas and get the correct legth(18,24,36,12 inches.
Nov 05, 2012 | Heating & Cooling
Will this solve my problem of the pilot going out after the water is hot?
Your thermo coupler may be going out. If the thermo couple does not sense heat it will shut the gas off. This is a safety feature. Once you replace that you should be ok.
Aug 14, 2012 | Camco 08773 Gas Pilot Assembly 9 Inch for...
Replace thermcoupler patio heater
I would first check that the thermo coupler is sitting inside the flame when you ignite the pilot light.
Replacing the thermo coupler can be a real hassle.
Mar 10, 2012 | Next Generation Power Engineering Garden...
The pilot light will not stay lit, I was told
Hi, this heater doesn't have a thermocouple, it uses a pilot generator which is more reliable so I doubt you need to change it out. First thing to check is that you have a clean "sharp" blue pilot, you should be able to hear it quietly roar. If it is yellow and appears "soft", the pilot need to be cleaned. The easiest way is to use a straw or tubing of some sort to blow into the pilot, gently tapping the pilot assembly. That should clean it up and heat the pilot generator properly. Tighten the the screw terminals at the control valve to assure good electrical connections and last but not least turn off the thermostat until you get a standing pilot. Good luck and stay warm.
Jan 13, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
