Question about Radio Communications
I have many base Radio CM360 have problem in sound no sound but have power i checked in speaker it is good but i need the layout for this model because i have 50 radio have the same model and always have problem thanks
  • Radio Commun... Master
  • 1,654 Answers
Before getting into the radio, I would check the following: If you are using hand mics, or a desk top mic, have you tried unplugging the mic and seeing if your sound returns? It could be a bad mic, mic cord or damaged mic connector.
Another thing to check would be the antenna connections and continuity. It is possible you are simply not receiving.
Posted on Dec 06, 2008
Volvo 2000 s 80 Radio/CD player screen lights up, but nothing comes out of speakers. Occasionally, I will here a speaker pop. How 2 diagnose? Water on floor. Possible damaged amp?
doesnt sound good ..water there
could be bad earths
amp may have a fuse
speakers need to be tested manually
these links may have wiring layouts etc
VOLVO Car Radio Stereo
Audio Wiring Diagram Autoradio connector wire...
Volvo Radio Wiring Diagram
Oct 11, 2016 | 2000 Volvo S80
I have a 2001 GMC Yukon XL and several months ago, I started having a problem with the OEM radio. The radio evolved to the point where it was in constant state of resetting itself on and off. The clock...
Initially, pls verify the splicing/wiring:
If verified and still no sound, either:
  • setting configuration (menu); or
  • internal fault of the Pioneer unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 26, 2008 | GMC Yukon XL Cars & Trucks
Radio sound low and squeeky, works good in summertime
The volume control on your radio is called a potentiometer, which may be going bad. It works better when its warm because materials expand as they warm up and make tighter contact with each other.
It is also a possible a bad wiring connection exists. Poor contact will cause static, poor audio quality and intermittent output.
Your radio will have plug type connector(s) Your speakers will most likely each have two wires with single female spade connectors of different widths (keeps the polarity correct) the wire with the stripe (of whatever color) will be connected to the negative (-) speaker terminal.
So you need to check all the connections, one is making poor contact.
If both speakers (assuming you have two) sound good or bad... then start with the plug connectors for the radio and any independent black ground wire coming out of the radio.
If one speakers sounds okay check the connections on the other one. You check the connections by carefully pulling the speaker wire off of the speaker and then carefully pushing it back on making sure it feels tight and secure.
PS: If you pull the fuse for the radio, the radio will have no power and will not work. The radio coming on proves the fuse is good.
PSS: Your owners manual should provide lots of information on your sound system components.
Aug 11, 2017 | 2000 Chevrolet Silverado
I HAVE A 1990 TOYOTA CAMRY AND I NEED A WIRING DIAGRAM FOR RADIO INSTALLATION.
does this help, or do you need more?
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 3 1/2?
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 17, 2010 | 1990 Toyota Camry
1994 nissan pathfinder radio wire diagram(Clarion model #PN-9661H
this is the layout below. But in my personal experience i just buy an adapter harness. But if you want to hardwire the information is below.
1994 Nissan Pathfinder Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Red/Black
Car Radio Switched 12V+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Yellow
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Roof Mount
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
if you need further information please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 31, 2010 | GPS
I have a cobra 135 base radio. It powers up and
It is possible the audio amp has failed. If I remember this radio it uses two push pull transistors for the audio amp. Check the mic connector as it may have a broken wire and that can cause a disconnection both ways. Lastly the radio uses a relay to switch from receive to transmit and the contacts can get dirty with age and this rig is getting old! This relay can be cleaned but use the striking surface from a book of matches as the points are silver or an alloy a palladium and can be damaged if cleaned improperly.
Feb 08, 2010 | Uniden Radio Communications
2003 mini base model. Radio don't put out any sound. Its a Harmon Kardon with a single disc player. Turns on, lights up, but just no sound. Any ideas?
sounds like the speaker wires have come loose, try to check at the speakers for voltage or sound, if none inspect the back of the radio.
Oct 27, 2009 | 2003 Mini Cooper
Uniden washington base station
I need the wireing information for uniden washington CB radio,thank you.
Oct 28, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
No sound
if the speaker system is not playing from any source eg radio,cd , hard drive etc.... check base module has power and system cable inserted correctly. also check the connection is firm at rear of media centre. once all has been checked turn power to both base module and media centre off for 1 minute . if this doesn't work post and we have more things to try
Nov 12, 2007 | Bose Lifestyle 38 System
Radio Communications Logo
57 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
