Question about Seiko Le Grand Sport SDWF73 Wrist Watch
Second hand doesent return to 1200 position after replace batt
My watch is a 22 year old Seiko sports 100 diver watch
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Posted on Dec 31, 2008
The gold trim box around the day/date feature of my Seiko 5 SNZH57 has come out. It now slides around under the crystal, and the hands catch on it. can I remove the crystal? Can it be replaced so it does...
You will need to remove the back of your watch and the movement to do this, don't remove the crystal... I usually just take the surround out but it can be glued back in place. Being a divers watch its best to get it done professionally so it can be resealed to ensure its water proof
Sep 30, 2013 | Seiko SNZH57K1 SNZH57 5 Sports Automatic...
My 5 year old Seiko kinetic (divers') watch: beyond shaking, is there a way to wind it? I used to be able to press the power button and see the second hand advance 20 seconds. Now I never have enough...
I am going to make an assumption or two. One is you wear your watch regularly. At least every other day. Two is you are not sedentary. Try wearing the watch for three days. If the power indicator doesn't read at least 15 to 20 you have a bad cell (capacitor). If it does charge up to 15 to 20 then see if it lasts very long. Should last a couple weeks or more. If not then you still have the same problem. You can also go to a watchmaker and he will have a piece of equipment that can charge your cell in 3 1/2 hours. Then if the cell goes dead rapidly he/she will replace it. Should cost around 50 or less.
Mar 13, 2011 | Seiko Kinetic watch
Hi.ive own a 70s seiko diver 6309-7040 an problem is now the watch is not keeping time (slow at least 5mns a day)can i do DIY adjustment on it..pls helpguide..thanks.
As thesed watches are sealed it is unwise to attempt any DIY activity.
As you have had the watch for many years it is very likely that it needs a clean. As it is so old, some parts may need replacing and this can only be doneby the maker. (Most makers recommend cleaning every 3 years or so).
If it is only just starting to loose time, then you have done very well out of it!
May 22, 2010 | Seiko Divers Automatic watch
The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (, click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Jan 23, 2010 | Watches
Can i dive with this watch?
You definetely CAN NOT dive with this watch. It is good for swimming and snorkeling only. Real divers watches withstand at least 200 meters of depths and are specialy designed for it.
One of the best affordable divers watch manufacturers novadays is Seiko. Check Seiko website and learn about divers watches and all the features they have. List of waterproof markings and explanations are also available.
Do not forget to rate, please.
Feb 12, 2009 | Casio W752V3AV men's watch
Minute Hand on Stopwatch Will Not Return to Zero
Here is the link where you can download manual for your watch:
The last chapter explains how to reset hands to zero.
Jan 22, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
Seiko Le Grand Sport SDWF73 Wrist Watch Logo
498 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Watch Expert? Answer questions, earn points and help others
