Question about Home
Electric shower is not getting hot
Shower was being used when the electric tripped, after that the shower is not getting hot.
  • 334 Answers
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
Posted on Dec 06, 2008
  • Danny Clark
    Danny Clark Dec 10, 2008
    So.... what WAS the problem?
Not getting any hot water all is turned on but only cold comes out i have hot water out of all other faucets but this one
There are a number of things that could be wrong. Most likely a breaker is tripped (or fuse blown), an element is burnt out, or there is a faulty water heater thermostat. From my experience, I would suspect a burnt out element but I would check the breaker first since it is easiest to check.
Oct 23, 2015 | Home
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
Electric shower just installed cuts out at fusebox after being on for about a minute
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
Oct 18, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
Why is my triton shower tripping electric shower casing feels hot(on top) too
According to me, you should contact to a professional that really helps you to get rid of this major problem. A professional can easily identify the problem regarding the triton shower.
Apr 17, 2012 | Home
Electric water heater typically makes 21 gallons hot water per hour.
Gas heater makes 41 gallons per hour.
If you use a timer on electric heater, it will make enough hot water for shower in about 15 minutes summertimer and 30 minutes wintertime. So incoming water temperature is a factor.
If your water heater is not full of water before turning on electricity, then elements will burn out.
Also the ECO might be tripped out: open top cover and push in red reset button.
How to troubleshoot electric water heater:
Have a mira sports shower. when i turn on at isolated switch light comes on but when i turn on shower light goes out. no sound of water coming to unit or electrical sound in unit.
Have you checked if when turning on the shower water the electrical trip switch turns off at the fuse board. If the shower does keep tripping the RCD then the shower is the problem.
Apr 01, 2011 | Home
On Memera fuse box, 30 amp fuse catridge carrier gets very hot, in fact can smell the plastic melting, but why does the 30 amp fuse cartridge (definitely rated as 30 amp) it is carrying NOT blow (240 volt...
OK well at 120 Volts at say 25 Amps (well below blowing potential) that equals 6000 WATTS 6KW, on a near short circuit. going through it...You would melt TOO.
I always use Ceramic ones myself, look they get HOT real HOT, BUT shouldn''t melt.
But in saying that your Electric shower shouldn't draw that much anyway, in reality. it may draw 10A - 15A, at most? more like 5A - 10A,
So i suspect you have a fault to earth somewhere you need to call an electrician. You may just have discovered a very bad fault. Some sort of short or leakage to earth or something?
A shower shouldn't draw anywhere near enough current to cause this type of occurrence. Please disconnect it by tripping the breaker and call a professional. get that melted one changed anyway.
Aug 11, 2010 | Water Heaters
Hi, my electric shower tripped the fuse yesterday. Since turning back on it now has hardly any pressure and has to be turned up as high as it will go and even then it is only slightly hot!
I think that the reason for tripping the breaker is a short in the wiring some where and thats is also why it wont get as hot as it should cuase the power is grounding out and going somewhere else
Dec 17, 2009 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
1,268 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
