Question about Dual XDM6825 CD/MP3/WMA Player
XDM6825 Not Playing MP3s in Stereo
I recently got and installed a Dual XDM6825 In-Dash Reciever. Everything went OK with the install, but when I try and play an MP3 CD, sound usually only comes out of the left side. Occasionally, it will come out of both sides, but I haven't figured out what causes it to start working properly. I verified that the CDs I made did in fact contain stereo MP3s. I also know that the wiring is good because whenever it is in Tuner or Aux mode, it comes out of all the speakers. Thanks in Advance, Mike
  • Mike Thomson Feb 14, 2007
    Sorry, I forgot to add that the problem occurs whenever any kind of CD is played, not just MP3 CDs
    Problem Solver:
  • 14 Answers
If you have a FM MODULATOR installed too,some ones no transmiting in stereo mode, try changeit
Posted on Feb 17, 2007
Dash lights only work when pressing brake
Undo what you have done as you have wired into the CPU system and it is sending the program haywire.. Seek help from professional radio installers as it is not a matter of just wiring in any where
Feb 22, 2014 | 2001 Dodge Ram Pickup 1500
Cd reciever how to install
There is one wire that connects to your ignition switch so the main stereo turns off when you turn your car off. If the radio still plays after you have turn your car off then you have your stereo directly feeding off the battery.
Jul 25, 2012 | Dual Electronics XHD6430
Where do i hook the blue wire up to on a dual xhdr6435 into the dash
Hi, the blue wire is used to turn on a separate amplifier or to raise the antenna. If you don't have a telescoping antenna or amplifier, just tape off the blue wire and leave it hanging behind the head unit. Please let me know if you have more questions, and thanks for using FixYa.
May 06, 2011 | Dual XDM6825 CD/MP3/WMA Player
Installed my dual xdm6825 into a 1998 honda passport. NO POWER. everything looks like it is connected the right way but still have no power. the only way power comes on is if both 12v (red and yellow)...
I suspect you may have a blown fuse. Either the red or yellow wire from your dash board should have power (+12 DC volts or greater) all the time relative to chassis ground, which should be the black wire. Use a voltmeter to measure this. The other wire (red or yellow) should only have power (+12 DC volts or greater) when the car is turned on or the key is turned to the Aux position. Use the voltmeter to measure this also. If one of these wires doesn't measure correctly you most likely have a blown a fuse. I think the Honda Passport has 2 fuse boxes. If you open the driver's door I believe you will see a panel for one fuse box on the left side of the dashboard. I believe the other fuse box is located on the passenger side of the engine compartment. Fuse boxes sometimes have a labeled diagram on their cover or you may be able to find a diagram in your owner's manual. Look for fuses labeled radio or dash. You should be able to easily pull them out with a pair of needle nose pliers. If you look carefully at them you can usually tell if they're blown because the wire inside will look broken. Replace any burnt out fuses with new fuses rated at the same current value. The current rating of the fuse is usually written on the outside and it will generally be a number like 10, 15, or 20. Most of the time the fuses are color coded by current rating. You can buy new fuses at any auto parts store, or if you're lucky there will be a few spare fuses inside the fuse box. I hope this advice helps you out.
Jan 06, 2011 | Dual XDM6825 CD/MP3/WMA Player
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
I need help with the instalation harness
Harness adapters are available for many popular cars that will make wiring it up pretty simple. I bought one for my Honda at Walmart of all places.
good luck
Oct 02, 2008 | Dual XDM6825 CD/MP3/WMA Player
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Kenwood DPX501 won't play mp3s that are burned onto disks
Does' it do both plus and minus cd's? It may only do CDR+ or -
Aug 13, 2007 | Kenwood DPX-501 CD Player
Car Audio & Video Logo
96 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
