Question about Dell Inspiron Desktop with AMD Athlon 64 X2 Processor 4400+
Beeping sound, wont turn on
Hello
i have a dell inpiron 35os, and recently when i turned it on there were 4 beeps over and over again, and the monitor would not boot. i reset the memory, but now it gives be 2 beeps, and still it wont start up. is there any way i can get it to run normally without replacing the whole thing or getting a repair?
    Sergeant:
    Novelist:
  • 190 Answers
From my experience you may be having a memory problem that is more than just a problem with reseating. When you reseated the ram did you pull the ram out and try one stick at a time? Or trying a different stick all together. I have had several go through the shop in the last year that I had to replace the ram in. Most were the 510e series but there were others as well. If you have more than one stick try just one at a time and in different slots. Also if you have plugin cards you my try unplugging them as well. When you said the beep codes changed by reseating the ram that makes me suspect the ram. Good luck and hope that helps....
Posted on Sep 20, 2009
    Genius:
  • 1,061 Answers
The beeps are beep codes.Some are long and some are short.go to dell.com and enter your computer model number.under support customer service search for your beep code.also an easier way may to go here http://www.bioscentral.com/postcodes/dellbios.htm.This will explain the codes and help you understand what is wrong.If you require further assistance contact me.RICHARDM69
Posted on Dec 06, 2008
My Dell Inspiron 545 desktop computer beeps upon start up. It beeps 4 times pause and repeat over and over again. Also the monitor screen is black and won't turn on.
Try to open the CPU
when you open the cpu remove the ram clean it with eraser carefully
or if you have IP solution try to clean the ram with it and again install the ram
Apr 13, 2016 | Dell Computers & Internet
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
Apr 01, 2011 | Dell Inspiron 530 Desktop Computer
System wont start just hear beeps
There might be problem with your RAM. Remove and Fix your RAM again... Let, me know if it doesn't work...
Feb 23, 2010 | Dell Dimension 4400 PC Desktop
My presario 1600 just beeps when I turn it on...
there are 4 kinds of beeps that the pc produce when you turn it on, base on your beep it is indicating that the memmory is damage,
a single beep means the pc is ok
and your beep is memmory damage
a long beep pause and then beep long again means video card damage
if the beep sound like a firetruck the processor or memmory is over heating
Sep 24, 2009 | Compaq Computers & Internet
Dell e771p monitor cant turn on. Noise beeping sound from monitor
The monitor is not worth fixing and I recommend replacement. The good news is that you've confirmed the problem is not with the computer!
Sep 16, 2009 | Dell E771p 17" CRT Monitor
Computer won't restart....
it appears that this is a memory problem, based on the codes that you specified.
the reference for this is:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124996
Aug 09, 2009 | Computers & Internet
4 short beeps on vostro 200 monitor shows black?
http://support.dell.com/support/edocs/systems/vos200/en/index.htm
the above link will allow you to download pdf versions or view HTML versions of the Dell manuals for your machine.
4 beeps is RAM read/write failure
if you recently installed new RAM (memory) you should check to be sure that it is compatible. If not, you might just have a loose memory stick.
just remove and re-install memory modules making certain to seat them firmly.
!!!! Very important ..before touching memory.. be sure to discharge any static from your body - by touching anything grounded (I usually leave my tower plugged into a grounded outlet and make sure the rocker switch to the for the power supply(the switch on the back of the computer) is turned off.
Aug 09, 2009 | Dell Vostro 200 PC Desktop
Computer problem
during these beeps there should be pause between them at some point...in other words you may get 2 beeps/pause/1beep/pause/2 beeps noting the number of beeps and where the pauses are will help. From what you are describing and without more info it sounds as if you are describing beep codes, and they generally can give us a lot of information.
Dell inpiron 350 motherboard not responding!
Sounds like defective North Bridge or needs reflow.
Mar 16, 2009 | HP Pavilion dv1000 Notebook
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
Dell Inspiron Desktop with AMD Athlon 64 X2 Processor 4400+ Logo
300 people viewed this question
Alun Cox
