Question about Whirlpool RF364 Electric Kitchen Range
Cant get whirlpool electric oven door hinges back on
I was cleaning oven i now i cant get it back on n
Pull the hinges out and there should be a hole in it to where you can slide a nail or a screw through to hold the hinge open so you can put it back on
Information is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196274.pdf
Posted on Apr 03, 2009
Remove glass oven door
The video on You Tube will show you how to remove your oven door. You may need to watch it all of the way through to see your type of hinge. The video shows four different hinge types which are common and so covers most oven models.
Oct 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I cleaned my oven and cant get the door back on
Pull the hinges out to the first stop, where you set the door when broiling, and just lower the door onto the hinge bars.
Nov 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door won't go back in place
open each hinge about 1/3 of the way open or until it reaches the point that it will stay open, align the door slots with the hinges and lower the door down onto the hinges. Door should operate properly now.
Feb 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cant get the oven door back on
Use a wrench to lower the hinge arms down. There is a hole in the arm that you can put a nail into through to the frame of the oven/ This should leave the arm in an outward position. Do this on both sides of the oven, or both hinges
Pick up the door, and slide the door onto the arms until they stop.
Press down on the top end of the door lightly so that you may remove the nails inserted above.
Lift the door to close. If you didn't slide the door onto the hinge pieces far enough, then repeat the procedure.
Jan 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Whirlpool double oven rb130pxv
As long as you line up the hinges with the receptacle in the door, it should slide right down. Try a shot of WD-40 on both.
Sep 08, 2007 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RF364 Electric Kitchen Range Logo
261 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
