Question about Thermador P304CS Gas Kitchen Range
Left two burners will not light. no spark
PRG304EH
I had the same issue with my harmony range. Read on another site that you need to turn the breaker off to reset the iginition system. I tried it and it works. Good luck.
Posted on Apr 26, 2009
One burner won't spark when another is aflame. Multi-ignition BlueStar 4-burner range.
I would check that the plates are on correctly. Make sure they are aligned and sitting properly. Sometimes they move while cleaning and give you a bad ground connection for the spark.
Feb 15, 2016 | Kitchen Ranges
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
Ignition
With the gas off, wait til it's getting somewhat dark out, and try the ignitor for the left burner and locate where it's sparking. If it's not positioned properly, or the wire has a short, it will not light the burner. Compare the ignitor positions for the other burners and adjust the sparking position as needed til it lights. Do not leave the gas on for more than 5 sec when trying to light it, so you don't have a build-up of gas and singe yourself.
May 13, 2010 | Lynx L42PSR (NG) All-in-One Grill / Smoker
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Left side two burns do not ignite
Check the ignitor unit, If the other side works, maybe a wire has come off the ignitor feeding the left side.
Sep 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
Electric start gas range
All burners apark at the same time. If they don't light then electrodes (where the spark jumps off of) are either worn out or cracked or there is dirt in the area of the sparking. Clean thoroughly to diagnose this correctly.
Nov 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Thermador P304CS Gas Kitchen Range Logo
205 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
