Question about Kyocera Mita FS-C5016HDN Laser Printer
Poor print quality - halo/smudge effect
Recently my printer has started this halo effect,like a smudge, principally on bold black print, although it can be seen a bit on the magenta and yellow. Have cleaned all charger units, advanced beam array lenses, done colour calibration, replaced toner and even replaced the black developer unit, and cleaned the paper chute and ramp, and changed to the latest driver. Still the problem persists. Any one out there who can help?
  • 3 Answers
Maybe the probem lies in the fuser this is a metal teflon coated tube (surrounded in fidly breakable plastic) with a halogen light running through the middle (for heat) it heats up and fuses the toner to the paper JUST before it leaves the printer (thats why the paper is hot when it leaves the printer) you can have the tube RE-tefloned for not much cost when i used to repair laser printers the company would post a re teflonned tube and i would send mine back so the client would not be without a printer while the tube was being re done - or you could just buy a complete new fused unit (not cheap) hope this helps
Posted on Feb 14, 2007
SOURCE:
Bold black writing prints blury/smudged. Colour and small/non bold black writing is fine. Replacing toner and cleaning printer doesn't help
This is common with this printer, the LED head will need to be cleaned and height adjusted - would be best to have a technician look at this problem as you can damage the LED head, Drum or make the problem worse.
Sep 09, 2011 | Kyocera FS-C5015N Laser Printer
After numerous cleaning cycles the nozzles on my Pixma MP970 still show streaked patterns when printing the nozzle check. This printer has always has had poor print quality mainly black text. We got it as...
It will need a new printhead, QY6-0062-000, around $80.00. Leaving it sit and not printing just makes the problem worse, as more nozzles on the printhead get plugged. You get 90 day warranty with refurbished units and if it started out crappy you should have had a shop look at it, that model can print super photos! A new printhead will bring it back to life.
Dec 24, 2009 | Canon PIXMA MP970 InkJet Printer
Bizhub C350 Black smudges on prints
Sounds like you may have a bad fusing roller. Run some blank sheets. If the smudges start to fade, that's your trouble. When the fusing roller is bad it doesn't clean as well, so when you run bold text or anything that has higher than normal toner coverage, there will be more build up on the fusing roller that then transfers to the paper.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Poor printing quality. halo/ghost effect
check if your cartridge has enough ink.
And try doing a maintenance task on your printer. Usually you can find it in the Printers application software or you can check the properties of the printer. Most of the printers have features on doing a maintenance like, paper feeding, deep cleaning, paper smudge realigning, etc. You can increase the printing quality also in the settings of the printer.
well, i hope this works.
Thank you.. :)
Aug 08, 2009 | HP LaserJet 1000 Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
The quality of printing is poor.
try a little water on a q tip and rub gently to remove any excess ink
Dec 08, 2008 | HP DeskJet 920c InkJet Printer
Poor print quality
First Perform deep print head cleaning if this fails and the print results are same then you may need to replace the print head on the printer .......
Good luck...
Sep 16, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Print Quality
clean the transfer roller and inside the printer .........
Mar 05, 2008 | Kyocera Mita KMR-1810P Laser Printer
Kyocera Mita FS-C5016HDN Laser Printer Logo
220 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
