Re: my computer cannot install things and open power...
You might have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Which email program hotmail ,outlook express , yahoo , gmail ...or are these email attachments or just email Have you tried right clicking select open ?
Restart your computer
repeatedly tapping the f8 key to enter safe mode while the screen is black once
in safe mode where the only things working will be your keyboard and mouse
allowing you to attempt to repair your computer.
Use
the system restore to restore your system to an earlier time click start all
programs accessories system tools you should see your system restore option if
it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur
before you install a program or a service
you can use the system checkpoints or the installation restore points to
restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run,
type msconfig, and then click OK.
2.On the General tab, click Launch
System Restore.
3.Select Restore my computer to an
earlier time, and then click Next.
4.Calendar dates in bold are possible restore
points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation
restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8
until you fix your configuration issue.
1> Check you speaker all connection point.2> Check you connect speaker lead out put Point.3> Power point Check to speaker.4> Installed Audio driver to mother board. Not any other Driver install only proper driver.5> If driver install then check it. a> Go to control panel- Add or remove program, hear show audio driver or not. if not show then install. b> My computer right click- property- hardware- device manager, if audio point yellow then install driver. if not yellow then install driver.
6> If all thing check then you speaker not support in you PC. Note:- Batter then Contact good Computer Hardware Engineer. More Computer Support.
Power point unfortunately does not come standard with windows. Power point is a feature of Microsoft office, which is sold separately from computers. In other words, to get power point, you will have to purchase a version of Microsoft office. I would recommend getting the 2007 or later version.
Please rate this post if it was helpful to you.
Best of luck with your endeavors.
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
to be able to open and make power point files you have to install the word software in your computer ..or at least the power point ..If you have the possibility I would recommend the office word 2007 ..but it is on license and it has issues even when you buy it.. so .the fast solution is to install power point alone ..or if you have word..look in the start ..all programs ..Microsoft word..and see if you already have power point if not..download this one ..it is a viwer that will allow you to view and open all power point files even the ones with password..but not to edit them .. http://www.microsoft.com/downloads/details.aspx?FamilyID=048dc840-14e1-467d-8dca-19d2a8fd7485&displaylang=en to beable to edit you have to install the word ful version ..
First off, you need to have a copy of PowerPoint Installed.
If you do, then in most cases you can click Start / All Programs / Microsoft Office / and click Power Point.
If you don't have powerpoint you can get the free powerpoint viewer to VIEW the slideshows without having powerpoint installed.
If you need to open a powerpoint slideshow and don't own microsoft office you will have to purchase a copy from almost any computer store.
If you have to make a slide show and don't have Microsoft Office you can always use the FREE OpenOffice software that can open most MS Office documents and has all the same features as MS Office.
open my computer local drive - program files - microsoft office - office 11 - look for power point if have make a shortcut on desktop if no then next step
stsrt - run in run type powerpnt.exe see if its open if no then next
clickon start - control panel- add an remove - highligh microsoft office - the clickon change - highlicght add an remove features - once you click on that if you getting various office component check mark all off tham and then clickon update or continue other wise if its prompt for installation option then clcikon microsoft office and then run all from my computer
let me knaoe the results thanks
Download "FoxIT reader" works better than Adobe reader to open the attachments.
You need to reinstall office to repair Powerpoint or you can go to Microsoft's website and download "ppviewer"
hello!
-- what is the exact model number of your access point and router? -- what is the ip address of your access point and router? -- what is the operating system of your computer? -- Is your computer directly connected to the router? -- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router Step 2: Make sure the power adapter is plugged to an available power outlet Step 3: Check if the corresponding LEDs on the access point are lit Step 4: After connecting the devices together, configure the access point’s wireless settings Step 5: Open the access point’s web-based setup page Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
