Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel top load intermittent running
Machine starts, and shuts off completely after 1-3 minutes. Entering diagnostic mode does not give any codes (no leds light). After unplugging unit for 1+ minutes it will start again, allow you to advance through different cyles, but whatever cycle you choose, the machine shuts down again after 1-3 minutes of running.
  • mcewans Dec 09, 2008
    I have the same problem. Replaced the motor controller but the problem remains.
  • Anonymous Mar 22, 2014
    The machine will sometimes start sometimes not. No error codes, the start light will blink,the drum rotates and after 1 minute it stops.
  • 145 Answers
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Posted on Dec 15, 2008
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
FISHER & PAYKEL TOP LOADER WILL NOT GO THROUGH ITS CYCLES AND WILL KEEP BEEPING WHAT IS WRONG?
I just had that problem. Do you have any water inside the washer? if you do drain it. Try running the diagnostic mode to drain the drain pump. then unplug the machine for 10 sec. then run the machine, that should take care of the problem. You'll find the service summary behind the control panel.
Feb 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GW11 not staying hot
WHEN I CALLED FISHER AND PAYKEL PARTS CENTER WITH THE SAME PROBLEM . THIS IS THE REPY I RECEIVED. "THE HOT WATER FILLS IN FOR A SHORT TIME, THEN THE DIRVERTER RECIRCULATES FOR A FEW MORE MINUTES, THEN FILLS THE REMAINING WATER LEVEL YOU HAVE SELECTED WITH COLD WATER. THE REASON BEING: (GET THIS) FISHER PAYKEL SAYS THAT THE AMOUNT OF HOT WATER AT THE BEGINING OF THE
CYCLE IS SUFFICIENT TO DISOLVE THE DETERGENT. AFTER THE DEVERTER CYCLE (THE SIDE RINSE AS YOU CALLED IT) THE REMAINING WILL BE COLD WATER FILL".
HE ALSO STATED MANY PEOPLE CALL HIM ON THIS AND HE SAID IN THE MANUAL IT IS EXPLAINED THAT THIS IS THE WAY THE MACHINE WORKS. SO MUCH FOR ECOSMART
Jan 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
471 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
