Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Zigzag lines in picture when first turning on the tv
Picture is distorted with zigzag lines when first turning on the tv, but after 1-2 minutes the lines disappear and the picture is clear. Initially the problem would correct itself within a few seconds, but as time goes on it is getting worse. thanks for your any help
  • 734 Answers
This is probably a short in the TV, most likely a ground problem.,, make a proper ground (earth) for the the TV.
that will Fix your problem.
Posted on Dec 02, 2008
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Picture Problem
In that set its usually a bad picture tube. The lines you are seeing are called retrace lines. You can take it to a shop and they may be able to rejuvenate the tube
Mar 13, 2009 | Televison & Video
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Westinghouse LTV-37w2 HD picture malfunction
Have the same problem, have found others too, but no solution yet...
Jul 15, 2008 | Televison & Video
Diagonal lines moving from bottom to top
sample of a line diagnally from bottom to top of page.
Dec 20, 2007 | Gateway LCD30TV Television
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
233 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
