Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet hf error
I can wash a load of clothes and get the hf error I then cancel this out and select drain/spin cycle and wash again it will wash fine next load I hf and select drain/spin cycle and once again washes fine this is constant off and on when I wash Please any advice have checked all hoses and water flow
  • crfegypt Dec 07, 2008
    We get the same H then F error. Sometimes the lights on the left-hand panel do not come on. Now, the washer door won't stay shut. If we hold it, the water will run. Cannot seem to complete a load. What now?
  • 26 Answers
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
whirlpool duet hf error - fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 20, 2008
For me, the HF code was caused by a stuck flow meter. From reading other sites, this appears to be a common cause of the problem, along with dirty filters preventing enough water flow. (There are clearly lots of other causes.)
http://www.youtube.com/watch?v=GnGQKYKJZM8 has instructions for replacing the flow meter. (I searched for "whirlpool duet how to replace the flow meter.") In my case, I took the old one off to test it by blowing on one of the ends. Initially, the air went through without much resistance. When I blew harder, I got the desired pinwheel/kazoo sound. (I lost track of the site that let me know what to look for.)
I reattached the same flow meter and the washer worked again.
Posted on Jul 15, 2012
Washer will not wash cloths ol comes up on at end of cycle
This was built by Whirlpool. Try pushing Pause/Cancel twice to clear the error then see if it will spin out. Make sure the drain hose is not kinked.
Dec 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport model WFW8300SW Have error F-22 and F-28, how to solve it? Thks
Relates to an electrical/electronic problem
Try the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code f 9
Try to clear it doing the following:
F errors usually indicate an electrial prible with the exception of:
FH water supply issue.
F2 drainage problem
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Hope this helps comment back if you need further help,
Error H F
My Manual says (HF) = Water Inlet Problem- Insufficient Water Supply
Select Pause/Cancel twice to cancel cycle - Unplug Washer to disconnect Power-
Check the following:
Water faucets completely turned on
Screens at inlet hose connection to washer clogged?
Water inlet hoses kinked?
Plug in the washer- re-select cycle and press hold to start-
same error- call for service..
May 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,703 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
