Question about Bosch Washing Machines
MOTOR DOES NOT TURN - Bosch Washing Machines
  • Bosch Master
  • 3,463 Answers
Assuming the washer fills and drains, then I would suggest that the brushes are probably in need of replacement in the motor.
It is the first thing to check
Posted on Dec 06, 2008
Pool pump turns on, starts clicking then turns off
It appears that the motor is overheating, and then it turns off. There is a thermal overload switch that will turn off the heater, and when it cools back down, the motor will turn back on.
A few things to check:
  • Debris in the impeller
    • If so, remove it, this is causing the motor to overwork
  • Was motor / impeller recently changed?
    • if motor was downsized from the one prior, it is overworking, because the impeller is still sized larger.
    • if impeller was upsized with an undersized motor, the motor is overworking
  • Is the motor louder than normal?
    • The bearings are probably failing and the creating the motor to labor.
Good luck
Mar 11, 2015 | Sta Rite Sta - Rite 1hp Dura - Glas...
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Motor humswhen turned on. Removed pump and rotated motor shaft, put back together and worked but made a loud clicking noise. turned off and tried to turn back on again. Motor just hums as if something...
I was going to mention the coupling, since that is new, then I would suggest motor brushes or new motor. As long as you are getting sufficient power to the motor. about minimum of 12-13.5 volts
Sep 28, 2009 | Washing Machines
1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Aug 23, 2009 | Drills
Dryer motor just hums
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
Frgidaire Tumble action washer
because of the grinding noise your talking about it sounds like the motor bearings are bad which would require motor replacement. but, thats normally not what cause the " not completly turning problem" your having. general thats cause be the motor speed control not sending the proper power to the motor. remove the belt and turn the motor by itself to see if the noise is really come from the motor and not the back of the tub. if it is the motor, replace the motor. if it coming from the back of the tub the replace the motor speed control. the noise coming from the back of the tub would just be the ball bearings and they do make some noise on this model but you wont hear it when the washer is running
Nov 26, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Washing Machines Logo
26 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
