Question about RSQ NEO-E500 DVD Player
No sound from rsq e500n
I HAVE MY SYSTEM HOOKED UP THE S-VIDEO CONNECION AS PER THE INSTRUCTIONS TO MY SAMSUNG HDTV. WHEN I CHANGE THE INPUT BACK TO TV I HAVE SOUND.WHEN I CHANGE IT TO THE KARAOKE MACHING I HAVE WORDS AND ALL THE OTHER FUNCTIONS BUT NO WOUND. THE WIRESESS MICROPHONES ARE HOOKED UP PROPERLY AND ARE REGESTERING BUT STILL NO SOUND FROM THE SPEAKERS. PLEASE HELP!
  • 3,153 Answers
S-VIDEO only carries the video signal and NOT the sounds.
You would also need to hook up the audio leads (red nd white phono) also for it to fully work.
Posted on Dec 26, 2009
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
How to Hook Up a Receiver to an HDTV
Things You'll Need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
I need to get image
Change the input on your television to the corresponding input of your DVD player's video output.
ie; if your DVD player is hooked up to Video 2, you need to change your tv input to Video 2.
You may have simply not hooked up the video input, as well.
Mar 18, 2009 | Samsung HT-Q100 System
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Just purchased Xbox 360. Have everything hooked up to the TV as per instructions. Nothing comes up on the TV. Anyone know why to help me out? Thank You, Jerry
On most TV's nowadays you have to put the TV into Auxiliary or Aux mode. Most TV's with that Feature have a separate button on the TV itself, and/or on the remote control marked Aux, or Video, or Game or something to that effect. Usually you know its in that mode by a completely blue screen, or completely black screen.
Also, recheck your connections to make sure your Video and Audio inputs are matching the color coded input ports in the back/side of the TV. In a poorly lit room its very easy to fudge the connection color-codings. Also make sure the cable is firmly connected to the back of the X-Box and that the Selector switch is set to Standard Defition-TV if only 3 of your Composite cables are hooked up. Or if all of them are plugged in and you have an HDTV, that the selector switch is set to HDTV.
May 15, 2008 | Video Game Consoles & Games
RSQ e500n
did the same thing on setting up! there is either a p/n or v-mode button on the remote try pressing it a few times! hope this works for you
Dec 22, 2007 | RSQ NEO-E500 DVD Player
RSQ NEO-E500 DVD Player Logo
142 people viewed this question
Top RSQ Televison & Video Experts
Are you a RSQ Televison and Video Expert? Answer questions, earn points and help others
