Question about HP Pavilion dv9000z Notebook
Narrator keystrokes don't do what they say they will
Hi - please let me know what are the correct keystrokes to get narrator to work on the pavilion tx 2000. thanks.
Back round voice for blind people don`t know how to turn narrator voice off
Check the so-called accessibility options and turn off the narrator.
Jan 08, 2014 | Computers & Internet
Dv7-1023cl problems with quick touch buttons
You don't need to activate the drivers. if you reinstalled them then they are there and should be working.
There should be alternate methods to using the quick touch keys, such as using the conventional methods.
For example to change your volume, just click on the megaphone at the bottom right near the time and adjust the volume. Or click Start/Control Panel and look for Audio or Sound and adjust the volume. Also click Start/Programs/Accessories/Entertainment and see if there is a volume control there. Also normally you can adjust the volume by keystrokes. Normally you would Press and Hold the FN function key near the bottom left portion of the keyboard and press the volume keys (there should be 3 volume keys, volume up, volume down and volume mute).
As for the Wireless there is a switch on the side or in the front of the laptop that controls the wireless. Also there are keystrokes that can toggle it off or on once the wireless switch is on. Normally you would Press and Hold the FN function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of a wireless signal )))) or it will have the icon of a tower with a wireless signal )))).
Apr 23, 2012 | HP Pavilion DV7-1023CL Notebook
Need to remove softner dispenser which is attached to the agitator. There is no center bolt, just two plastic fins which are part of the agitator. Do I try try to turn this counter clockwise to remove. ...
Hi
To replace the Soap dispenser please see this video and follow the step by step procedure as narrated and shown there.
Hope this helps...please post back for further assistance.
Daniel
Jul 11, 2011 | Maytag Legacy Series Top Load Washer
HOW TO COPY NARRATION GIVEN UNDER AN ENTRY IN RECEIPT/JOURNAL VOUCHER TO OTHER ENTRY IN THE SAME VOUCHER USING TALLY9.
HI,
Please follow the below step for copy of narration.
Step 1: do entry right narration in one voucher and save this entry
Step 2: when your complete the entry in same other voucher then come in narration and press Alt+R
Thanking you
davevipul197
Dec 22, 2010 | Computers & Internet
I would like to disable narrator on my HP HDX 16 laptop as it starts on computer start up and i never use it anyway!!! thanks :)
go to Control Panel -> Ease of Access -> Ease ofAccess Center -> Explore all Settings -> Use the computer without adisplay. Uncheck the checkbox by Turn on Narrator and click Save.
Sep 06, 2010 | HP Pavilion dv9000z Notebook
I have a Dell inspiron and it has a narrator option. I didn't know what is was so I thought I would try it just for fun. Dumd me! Now I can't turn it off. It is starting to drive me crazy. I tried going to...
Hi palmtree125
If you go to Control Panel > Ease of Access center then under 'Explore all settings' click on 'Use the computer without a display'. You can then uncheck Narrator to switch it off.
Does this help?
May 02, 2009 | Dell Inspiron 1525 Notebook
I Can't Turn Off the Microsoft Narrator Off... When I turn My PC it's still there.. May someone tell me how I Can turn it off Completely....
click Start>Control Panel
Select Ease of Access to enter the Ease of Access Center.
Click Optimize visual display which is familiarized with the tagline "Make the computer easier to see".
Uncheck the boxes for Turn on Narrator and Turn on Audio Description under Hear text and descriptions read aloud.
Click Save and close the Control Panel. After restarting your computer the Microsoft Narrator will no longer voice.
Mar 08, 2009 | HP Pavilion dv9000z Notebook
(Microsoft ?)Narrator on new HP Paviolion dv9910 laptop(model# on comp.)
hi car8846 try this press the windows key on the keyboard then holding it down press u
the utility manager appears - click on the narator click stop then uncheck the boxes also so it doesn't start back up on reboot.
hope this helped.
Nov 02, 2008 | HP Pavilion dv9000z Notebook
Microsoft Narrator
Hi berbob,
There are a lot of keyboard commands to help you, the first being [Crtl] + [Shift] + [Spacebar] to read an entire window after clicking it. If you are in the main Narrator console, press the [F1] key for help. If you expand the Narrator topic, "Navigating with the keyboard and Narrator" should be displayed as a subtopic. This contains the keyboard shortcuts to help you navigate Windows.
If getting to Narrator is difficult for you, press [Ctrl] + [Esc] (equivalent to clicking on the Start menu), press [R] (for the "Run" command) and then type the word narrator, followed by the [Enter] key.
Hope this helps,
Jason,
Go Ahead. Use Us.
Jul 21, 2008 | Computers & Internet
Hi. HP pavilion ZE2000 Turning off when i try to instal windwos xp
Unless you have a FRU manual for your model and you feel very comfortable taking your laptop I would avoid it and send it out for repair. If your laptop is restarting I would remove the CPU, clean and put thermal paste and put it back together. You can use canned air to clean many of the parts that you can see.
Sep 08, 2007 | HP Pavilion ze2000 Notebook
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
