Question about Toshiba (P000257700) Microphone
Built in mic
My built in mic not working may the software it listen to the sound from the laptop
    President:
  • 373 Answers
Goto the Volume icon in the tray on the right hand side of the taskbar.Open it.Goto the recording properties and change the recording option to microphone.The initial setting could be with a Stereo mix.Once you did the necessary change, the recording should be normal.Please do rate if this solves the problem.
Posted on Dec 07, 2008
Built in mic not working
You may be able to solve this by clicking around in the sound settings (start > control panels > sounds). Often the mic is muted.
if that doesn't work, get an external laptop mic for .99c on eBay/amazon. This will also sound a lot better than the built in one too. Good luck
Jan 19, 2014 | HEWLETT-PACKARD Computers & Internet
Lenovo ideaPad U260 built in mic doesn't work
Hello, "Ana Gonzalez".
Your problem sounds like you don't have the software setup right.
Since you could post your problem here,
I suggest that you either use the Lenova website to research this,
or check out the website for their support options.
I've seen a number of systems with software settings improperly applied, causing the microphone to malfunction.
Or to cease to function at all.
Without either a screenshot or the exact name and version of the software, its not possible to more precise.
However, IF you can open the software for the audio control, the volume, and the mic, then you should check to make sure that it is setup correctly.
Hopefully helpful,
sl0j0n
Jul 27, 2012 | Lenovo IdeaPad U260 Laptop Computer -...
My mircophone is not working on my MSI laptop
Hello Freshnoble, hi! try first the sound recorder program, for testing purposes, if you are using XP, it goes, start, all programs, accessories, entertainment, sound recorder. Shout on the mic, you should see wave pattern on the sound recorder program. if not. the problem can be hardware and/or software. If its the hardware, check the microphone, is the mic built-in or are you using an external mic? if built in, try to enable first the microphone, right click the speaker on the lower right side of windows, select adjust audio properties, sound, at this point you should see the sound recorder device, select mic volume and adjust it all the way. test again the sound recorder. If you did not reach this point, there is some thing wrong with the device driver, load the sound driver first and test the mic again.
Mar 12, 2010 | Computers & Internet
HOW DO I KNOW IF MY COMPUTER HAS A MIC BUILT IN?
You will most likely see it on top of the new monitors now on the market. If you dont see a pink cable on the monitor you dont have a built in mic.
Dec 15, 2009 | Dell Inspiron E1505 Notebook
How to install the mic?? can i download the software and install it??
mac laptops have built-in mics.. Launch the system preferences panel and you can control the sound input via the sound portion of the sys. prefs.
Oct 30, 2009 | Computers & Internet
How do i get my asus k50 webcamera to produce sound?
webcams dont have mics...the mics are built into the bezel around the screen and are controlled by the sound drivers. You have to use the webcam software to link the sound drivers to your webcam software so the two work together when you are on video messaging. Check into the webcam software documentation. I know that when I was setting up my webcam in Gmail, it was linked to the sound drivers automatically.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
Speakers sound hollow. mic in sounds like squirrel
i think you're driver did not do the right setting for you. try searching drivers from this site http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm or search realtex HD manager. They will do all the work for you
Aug 02, 2009 | Toshiba Satellite A355-S6935 Laptop
Lenovo G3000 38Q - built-in mic not working under Windows XP but built=in speakers are working fine. How do i solve
I believe the problem is that your mic isn't working properly so follow these instructions:
1: Go to control panel and click on "sound"
2: When the sound window opens click on "recording" you should find the built in mic there in the dialog.
3: Click on your built in mic and click on configure.
4: Then, click on "levels" and set the microphone level to 50 and the microphone boost to +20.0dB
If that doesn't work try doing a system restore.Or you could try restoring the defaults on the sound pref.
Jun 26, 2009 | Lenovo Computers & Internet
Acer aspire 4720z Built-in microphone only records loud static
You did great troubleshooting for your laptop. If the sound is fine and good for the headset, your sound card is probably not the problem. The driver aspect, should not be the problem either if it works with your headset. So herein lies the dilemma...the problem is most likely due to some physical componenent between the built-in mike and the computer case itself. You should take it to a laptop repair shop and see what they can do. It has nothing to do with the software or the sound card. It is the physical component of the built-in mike and speakers. Get that checked out and you should be good to go!
Nov 15, 2008 | Acer Aspire 4720 Notebook
Nx7010 mic problem
Did you check the sound settings for the mike?
May 08, 2008 | HP Compaq nx7010 Notebook
1,000 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
