FixYa.com
Tags:
Nikon N80 35mm SLR Camera
My night shots are troubleWhat camera features are...
By Perkins - usenet poster
My night shots are troubleWhat camera features are most important for taking night photos?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by oldfilmguy, posted on Mar 09, 2008
This camera is a very simple point and shoot camera. All of the special features you have mentioned don't apply. ISO numbers on a camera? That's a digital thing not a film thing. The film has the ISO numbers and the camera accommodates them. However, this camera is so automatic, that there is no way to fiddle the ISO numbers like on a regular SLR. I expect that there has to be a way to use fill flash - that is what I keep hearing at other sites - and one of the settings on the dial on the back of the camera. Beyond that, I expect this camera will not do well with night photography without going to high ISO number film and that has its own grain issues. The user also has no way of knowing whether the camera is putting the f stop as the priority and then slowing the shutter down or visa versa. That makes it very hard to do much of anything special with this auto focusing point and shoot camera. Can you add anything that would indicate the specific settings on the dial on the back of this camera that would help?
Best Solution
posted on Aug 08, 2005
FixYa! (100)
pawa
pawa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Night photography can be tricky. Generally, you have to allow for long exposures, which can result in "noisy" (or grainy) photos. If you are interested in night photography, here are a few features to keep in mind:
High ISO numbers. Cameras with higher ISO numbers require less light for exposures. This means, you can take your night photo with a faster shutter speed and still get the same result (taking night photos with high ISO can result in noise, which impacts the overall image quality).
An allowance for long exposures. Long exposures allow the shutter to be open longer to absorb the available light.
Image stabilization features. This prevents movement during long exposures. Night scene mode, if it is available. This setting automatically provides low-light settings and doesn?t require you to manually modify the settings. This option is good for beginners who are still learning about the different available exposure options.
Noise reduction mode. Long exposures often allow noise ? or grain ? into your photo. Rather than use photo manipulation software to remove the noise, this setting automatically removes it for you.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Canon EOS Elan IIE 35mm SLR Camera Canon Sure Shot 80U 35mm Point and Shoot Camera Canon Sure Shot 90U 35mm Point and Shoot Camera Canon Sure Shot 65 35mm Point and Shoot Camera Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera Canon EOS-50E 35mm SLR Camera Canon EOS-AE-1 35mm SLR Camera
Can you Help with these Film Cameras problems?
no power :(
I took my camera out the other... Answer This...
The AF-Assist Illuminator
The AF-Assist Illiminator on my... Answer This...
film not always advancing
For some reason my N80 is not... Answer This...
Film will not load
I recently came across a Nikon... Answer This...
Double Exposure The Easy...
I can set my camera on multiple... Answer This...
Repair Service
Find Film Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
