Question about Toshiba Satellite M45-S2652 Notebook
Toshiba Satellite laptop takes over 20 minutes to start up
I am a pretty savvy comp user, but this has me baffled. My Toshiba laptop is less than 2 years old and now takes over 20 minutes to start. I defragged, scandisk, registry, it's none of that. I also noticed the DVDRW no longer opens when I press the button. Is it possible that a failed hard drive could stall the start up process? When I view the startup log in the DOS-type display, it just hangs on the memory counter for nearly 15 min, then starts. Once started, the computer runs slowly but is still workable. I bought an external USB hard drive and an OEM copy of WIndows XP ,but I don't know how to wipe the hard drive and still have the external cd drive work so I can reinstall windows and not turn my laptop into a doorstop. As I said before, I'm pretty savvy (in software/windows tech support for 4 years) so you can "speak geek" with your answer. Thanks!
  • sonu_nishant Feb 08, 2009
    My laptop starts very slowly. display starts very slowly, internet connection could not take place immidiately. even speed of surfing is slow
  • 340 Answers
Hi Marshall, and welcome to FixYa,
Have you tried everything?
Perform the steps given below to increase your system performance.
Uninstall all unwanted software:
To uninstall software
Click on Start
à Settings à Control Panel à Add/Remove Programs
Select the software (one at the time) from the list and click on the Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Now, antivirus program? Have you got one?
http://free.avg.com/download-avg-anti-virus-free-edition
Next :-) please vote if this help you
Posted on Dec 06, 2008
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
My adapter is lose and is not making a good connection to charge ...what can i do to fix it ?
If you are not good at tech, you should take it to a tech center to fix it, that will cost your at least $20, so you may replace it with a new charger, buy one from an online store, it is less than $20:
Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
Nov 21, 2012 | Toshiba Satellite C655-S5512 laptop
Tip
How to Reset Toshiba Satellite Password
"How do I reset my admin password to my <b>Toshiba Satellite laptop</b>? How to bios password reset Toshiba Satellite? I want to <b>factory reset Toshiba Satellite</b>, etc." Large amount of questions on <b><a href="http://www.windowspasswordrecovery.net/">Toshiba Satellite password reset</a></b> can be shown at anywhere. What should we do if we have to <b>reset password Toshiba Satellite</b>? Now, it is time for us to discuss such problem now!<br /><br /> 1. Is there a <b>Toshiba Satellite </b><b>recovery disks</b>?<br />If the <b>Toshiba Satellite recovery</b><b> disc</b> is created before we lost password, it will be helpful for us to solve the problem. The operation steps can be referred to <b><a href="http://windowspasswordrecovery.net/article/toshiba-password-reset.html">Toshiba Satellite password removal</a></b>.<br /><br /> 2. Are there still other accounts with administrative privileges?<br />Especially, we may always ignore the default or built-in administrator account which will save the day, such as in Toshiba Satellite XP, Vista. While, <b>Toshiba Satellite Win 7</b> has not default account password. Take Toshiba Satellite Windows 7 account with administrator rights as example: <br /> Step 1. Login Toshiba Satellite PC from the available admin account.<br /> Step 2. Start - Local Users and Groups - lusrmgr.msc (input in the Search box) - ENTER - Local Users and Groups - choose Users.<br /> Step 3. Right click the account needed to reset password, and then select Set Password.<br /> Step 4. Input and confirm the new password.<br /><br /> 3. <b>Toshiba Satellite Password Recovery</b> with free tool - Ophcrack <br />Ophcrack cracks passwords no longer than 14 characters using only alphanumeric characters. We can download its ISO image file online and then burn the file into a CD/DVD. <br /><br /> 4. DIY a <b>Toshiba Satellite </b><b>password</b><b> re</b><b>covery disk</b><br />If we are still in trouble of password cracker, we can easily get out of problem by DIY a password reset disk with professional Windows password recovery tools. There are many Windows password breakers or removals. Just take one of the most proven effective tools - Ainorsoft Windows Password Recovery as example:<br /> Step 1. Download <b><a href="http://windowspasswordrecovery.net/download.html">Windows Password Recovery</a></b> and burn .iso file to a bootable CD/DVD/USB Flash Drive via an accessible PC.<br /> Step 2. Boot the locked computer from CD/DVD/USB.<br /> Step 3. Unlock lost Toshiba Satellite password with the burned CD/DVD/USB.<br /><br /> Easy for us to break or recover forgotten Toshiba Satellite password now! The above four methods can make sure that we instantly <b>reset password Toshiba Satellite</b> laptops or notebooks for Windows 7, XP, Vista, Server 2008, 2003, etc. <br /><br /> <i>Source</i>: http://windowspasswordrecovery.net/article/toshiba-satellite-password-reset.html<br />
on May 18, 2011 | Toshiba Satellite L500 Series Notebook
Toshiba Satellite A205-S4707 Boot time is to long need help
you may need a fresh install of the OS, maybe upgrade the ram to 2-3gb, or the worst case factory discs for series model laptop.
Oct 19, 2012 | Toshiba Satellite A205-S4707 Notebook
Laptop powers on but screen is black
Please try to remove the Battery and wait for a few 2 minutes and then put it back on. Also if you have connected any USB devices, please unplug them and try starting the laptop. This is a simple step that you can do.Hey you can get the help from TheBestPcDoctor.I got great help from them and now I am a computer savvy person.You can contact them @
www.thebestpcdoctor.com or via 877-407-9229
Oct 03, 2011 | Toshiba Satellite L305D-S5938 Laptop
Screen very dark, can't see
Your inverter board burned out. I had the same problem. you will need it replaced. the inverter board costs less than $10 on ebay. but, you will need to completely take a part your laptop to do that. so if you are tech-savvy, then you should pursue the adventure. otherwise, you should just give it to geek squad and be ripped off.
Nov 30, 2010 | Toshiba Satellite A135-S4527 Notebook
My toshiba satellite A205-S5804 shut off after 20 minute and i upgrade my system to windows 7 but i do not know why it shut off after 20 minute?
If you leave it on without using it, it will turn off to save battery. This can be changed in Start > Control Panel > Power Options.
Otherwise, it is overheating. But this is unlikely. Try the Power Options. If you can't find it, type Power Options in Start Search box.
Aug 22, 2009 | Toshiba Satellite A205-S5804 Notebook
No sound
Your speaker wires may be disconnected from the sound board. See diagram 15 at http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-2.htm . It's pretty easy to peak into the case when the front case screws are removed.
Dec 18, 2008 | Toshiba Satellite P105-S6024 Notebook
Upgradation of RAM in Toshoba Satellite in A 80 model
Follow the link below to Crucial.com. It shows that your laptop can handle 2gb of ram. It is easily upgraded and takes less than 10 minutes.
http://crucial.com/store/listparts.aspx?model=Satellite%20A80%20Series
Dec 09, 2008 | Toshiba PTS53U-03K00M Notebook
Toshiba M45-S331, Black screen
I just went through all this myself. First I had the inverter replaced ($200) and it worked great for a week, then the screen went out again. It turned out that the LCD needed replaced ($200 more, labor comped from the first no-fix). There's a problem with the Toshiba LCDs that makes them burn out sooner than other brands. Since the replaced screen, no problems (2 months). Sucks, I know.
May 07, 2008 | Toshiba Satellite M45-S331 Notebook
Very slow startup and keyboard stuck on "f"
sounds like a software conflict. can you start it in safe mode?
Oct 21, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite M45-S2652 Notebook Logo
564 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
