Question about Roper RAB2121KW Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
I have a kenmore top loading washer that is about 10 years old. I find that many times, but not all times,  the spin cycle is leaving the clothes somewhat wet. It drains and spins but not enough to get all the water out of the clothes. If I run the spin cycle again, then the clothes will be much dryer. any ideas about what is wrong?
    Genius:
  • 1,122 Answers
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
2 Suggested Answers
  • 686 Answers
SOURCE: My Kenmore 90 serise washer leaves clothes wet. It
post your model number please
Posted on Apr 24, 2009
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer leaves clothes extra wet, need to dry double time
when it spins can you stop it with your hand, to try this put it in the spin cycle then push the lid switch with a pen and hold the tub if you can your problem is a spin basket drive if you cant then let me know
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing machine spin cycle
if a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Oct 06, 2007 | Kenmore 22622 Top Load Washer
Kenmore 23832 top load washer
lalocke If the load is not properly balnced, your washer will shake too much on the spin cycle and it wlll never go on full speed. Gendos...post back
Mar 01, 2007 | Kenmore 23822 Top Load Washer
Roper RAB2121KW Top Load Washer Logo
1,505 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
