Question about Oster 6329 2-Slice Toaster
Oster Toaster The R3 resistor on the board has blown up (fried)...I cannot see the color shema. Board XB8216. Does anyone has the specification for those?? tks
  • 1 more comment
  • blah Dec 14, 2012
    Hey People! I am new to this and found it while doing an online search to try and fix the toaster for a friend. I tried the R3 and Q2 suggestion but it still doesn't work and now the led lights flicker when I plug it in. Any help?
  • Anonymous Mar 30, 2014
    magnetic hold down not working toaster elements don't ernergize
  • David Brown
    David Brown Apr 20, 2014
    Same problem here did you ever find the resistor value?
My Oster Toaster stopped popping up after a couple of years as well - the lever just stays down until you unplug it or the toast catches on fire.
R3 was burned and replaced per the info on these discussions to no effect.
So I mapped out a rough schematic from the board and found some interesting things. Oster seems to be directly rectifying the line voltage (dangerous but cheap) through D1-D4 into 5V through DZ4 and 32V through DZ1.
These voltages seem to be across R3, which means it has 27V on 1K or about 0.73W on it continuously! Not only is this a waste of power, but it will always burn a 1/2W resistor. I would recommend replacing it with a 1W or larger and setting it up off the board to dissipate the heat into the air.
Then when toasting, the NPN transistor Q2 pulls to GND one side of the coil that holds the lever down. R3 is used as a series current limit for the 32V supply to the other side of the coil (so it has 32V or over 1W on it when toasting).
My problem with the toast not popping up was related to Q2 being blown. I don't remember the original number since I cut it out, but they seemed to have used an audio transistor with a Vce of 20V and Ic of 20mA. No wonder it blew with 32V and 32mA on it - bad design from the start.
I replaced Q2 with a cheap, commonly available 2N2222 - it has the same pinout and is good for 1A and 50V. It's been working great for months, but sadly still burning almost 1W continuously or over 6KWh per year.
-Jeremiah
Posted on Jul 19, 2008
  • vjohnson473
    vjohnson473 Jul 25, 2012
    How did you determine DZ4 was a 32-volt zener? Does it have a "1N" number, or did you measure it?
  • David Brown
    Thanks so much for the useful information! Will order a resistor and a new transistor and save the landfill a toaster!
I too had the blown R3 resistor. I replaced the fried resistor with BRN-BLK-RD-Gold 1 watt version. The toaster still would not eject toast without being unplugged. I then picked up a 15 pack of 2N2222 NPN transistors at Radio Shack (about $2.50). After replacing the Q2 with a new transistor the toaster now works. Thanks for the help.
Dan
Posted on Dec 29, 2009
  • 944 Answers
Doesn't seem to be available info in english - do you have any idea where the board was assembled? you could try these guys: http://www.sparkfun.com/commerce/hdr.php?p=contactus they have several different oster models details and might like the challenge best other solution is "yellow pages" or whatever you have - phone any repair shops and ask them if they have the same model in for repair. if you don't have it, here is the user manual, which although no schematics does have a long list of telephone numbers to call: http://www.oster.com/manuals/oster/006329-000-000_English.pdf Hope this helps :)
Posted on Feb 28, 2007
    New Friend:
Guess this is what is called planned obsolences. You would think Oster would realize we are onto them!
Posted on Jan 25, 2013
  • 26 Answers
I too have the Sunbeam/ Oester Toaster with a poofed R-3 Resistor,
We found a charred resistor loose in the bottom when we shook it upside down. I replaced it with one that was about the same size as the space provided and that was 1K and soldered it in.
The toaster c.b. still does not function. I am wondering if I have two good solder joints as the foil did not which well to the solder.
Also I am wondering if the board can be purchased. I would like to know if anyone has successfully replaced the R-3 and if so what wattage? Anyway thanks to the Guest who told us it was 1000 ohm. I had one in the basement and it impressed my son!
Posted on Dec 20, 2007
  • Harry  Flotemersch
    Harry Flotemersch Dec 20, 2007
    C.B that contains R-3 1000 Ohm resistor is number XB8216. I have replaced the resistor and the connection was not initially good because the trace was burned also. I made a bridge with some wire and now the blue lights work but the toaster still does not pop up after a time delay. Only way to pop up is too unplug. Cancel does not work. Where can I buy a C.B.?
The color code for R-3 is BRN-BLK-RD-Gold. 1K ohm. DD
Posted on Jul 17, 2007
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
My wife's Viking 6690 smoked this last weekend. I opened up the end where the power switches are and the board had a 0.01 ufd capacitor the blew up. That would be easy enough to repair. However when the...
According to you your machine's resistor burnt out. This resistor is located above the 240 volt capacitor which white base. change the resistor soon. For color code of the resistor you can follow the manual. You can visit also the product website for tech assistance.
Mar 10, 2011 | Vacuums
The lever to push down the toast will not lock in to start the toastng cycle
Inside the toaster (behind the toast, bagel, etc. Buttons) there is a magnet, this needs to be clean for the taster to lock. First, unplug the unit. Now remove the cap on the thumb lever and the four screws at the bottom, separate the toaster. Now you will see the magnet, remove any debris with a dry towel or with your finger tip. After properly re-assembled this should work.
Dec 20, 2009 | Oster 6330 4-Slice Toaster
The indicator light is out and the toast does not pop up on it's own.
the heating contacts are fouled up need cleaning not a big job can be done with a screwdriver and a nail file...
Oct 28, 2009 | Oster 6307 / 6309 2-Slice Toaster
Microwave goes on but does not heat
  • Magnetron is fried. Resistance between the magnetron terminals should be less than 3 ohms. Resistance from the magnetron terminal to ground should be infinite.
  • Fried HV capacitor. Use your ohm meter to test it.
  • Fried control board. If power is going to the board but not going off to the other components, the board is bad and needs to either be replaced or track down the bad connection (GE/Hotpoints).
  • HV Rectifier is shorted or open. Test forward and reverse bias with a megohmmeter. If continuity in both directions, rectifier is shorted, replace. If no continuity in either direction, rectifier is open, replace.
  • More help on testing specific components inside your microwave oven in this handy chart.
Aug 14, 2009 | Oster 4877 / 4878 / 6209 Toaster Oven with...
On my GE 169127 Toaster Oven, R2 on the 125301 DC motor circuit board appears to have burned out, the motor is not running but will run when test hooked up to a 9 volt battery, Can this resistor or cicuit...
In my case I found a capacitor on the 9 volt motor control board blown open. It was rated for 250 v but no mfd rating. I called the 877-207-0923 option 4 number. The GE toaster is warrantyed for 2 years. I was able to exchange it for a newer model at the same price today. The new one checks out just dandy.
Aug 14, 2009 | GE 168947 Toaster Oven with Convection...
Blowin resistor on my Acoustic Research S112PS
When I put an ohm-meter across it, I get 505-ohms. The color code looks like maybe green, dark brown, brown? Mine is discolored too. Green, brown, brown would be 510ohms. . .so that must be it. The tolerance band is gold, so that's +/-5% so that would explain the 5 ohm variance.
Feb 12, 2009 | Acoustic Research S112PS Subwoofer
Blown resistor
if you mhave the circut diagram please check it .
Nov 23, 2008 | Electronics - Others
Trying to fix my Oster 6309 and can't seem to remove . . .
The lever actually comes off another way, turn the toaster upside down and you will see a small clip holding the handle to the metal arm inside, you can pry it off with aa small screwdriver
Nov 17, 2007 | Oster 6307 / 6309 2-Slice Toaster
Oster 6329 2-Slice Toaster Logo
1,003 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
