Question about Drills
Ryobi cth 1202 charger will not charge battery
On the inside of the charger there is a curcuit board that has a transitor or a diaode that is burned out.could you please help me find a wiring diagram or identify R6 on the curcuit board thank you yard3 p.s. cordless drill charger
Ryobi 40022 trimmer (40v lithium battery) has completely stopped working. Battery and charger kept inside when not in use. Battery indicates that it is fully charged when in the charger. Any ideas?
Sounds like a bad charger my friend..test suposly charged battery with a multimeter and you will find your answer...can also test charging unit with it too...GL
Aug 13, 2016 | Ryobi Garden
I have a ryobi 18V battery and the only charger I have is a ryobi 14.4V. Can I charge the 18V battery on that charger?
Hello, unless the charger specifies that it charges 18 volt, it will only charge a 14.4v properly. If the battery fits the charger physically, then the most you might get an 18v to charge at is 15 or 16 volts. Your battery life will be shorter and you might damage the charger. I hope this helps.
Jan 12, 2011 | Ryobi Garden
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
How do I check and replace fuse on Ryobi CTH 1202 Charger?
AT THE BOTTOM OF THE UNIT YOU WILL FIND LIKE 8 TO 12 SCREWS,UNSCREW THEM.aFTER THAT YOU WILL SEE THE FUSE that would be a 2.5 amp fuse.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | Ryobi Multi-Volt Battery Charger
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Nov 08, 2010 | Ryobi Multi-Volt Battery Charger
I have a ryobi impact drill and battery charger that has stopped
yes, most chargers have internal fusses.
Oct 23, 2009 | Drills
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
RYOBI CTH 1202 does not charge
Check the output of the charger with a voltmeter. The nameplate shows the output voltage expected. If it checks ok, the battery is defective.
Aug 28, 2009 | Drills
Ryobi charging stand BCSC12C does not charge battery
i have a manul that you can fix all your batterys ,very easy email me i will send you the file cheers at pfcatering@optusnet.com.au
Feb 13, 2009 | Ryobi Multi-Volt Battery Charger
Drills Logo
190 people viewed this question
Top Drills Experts
EugenesDIYDen
EugenesDIYDen
Are you a Drill Expert? Answer questions, earn points and help others
