Question about Panasonic SC-DT100 System
Error 'F61' can anyone help please?
Hi, I have a friend who has a Panasonic SC-DT100 system which has recently shown the error number 'F61'. According to the manual this is either "Check & correct the speaker cord connections, or if this does not work there is a power supply problem" Well I know from my friend the speakers were all connected ok as it has been working great up til now. So I can only assume it is the power supply. What I'd like to find out is... 1. Is this a costly part to replace & where can I buy one from? 2. Should it fairly straight forward to swao the supplies over? 3. If my friend were to take it to a Panasonic approved repair center would it cost alot (I tend to think it might). I'm normally ok when it comes to sorting out electrics but I thought this would be the best place to ask for advice. Any help or advice would be gratefully appreciated.
  • 1 more comment
  • laf61 Nov 27, 2007
    I have the same problem with my sc-ht740 . I took it apart and eveything looks fine. Is it the powersupply? Help!
  • blue 01 Sep 28, 2008
    It seems that I not the only one with this problem [F61]
    I turn on the unit it powers up and then " F61" comes up and the unit turns it self off has anyone any itea
    I have checked all the speaker cables and the power supply and all seem fine
    Some one must be able to help with this
    Ta
  • butterlip Dec 22, 2008
    How do I fix the power supply problem?
My unit had the same F61 problem. Open the hood, put one hand yout back to prevent electrocution and power it on. The fan turned quite slow wit a grinding noise. I replaced the fan (specs 4x4x1 cm 12V 0.2A) with another fan (specs 4x4x0.5 cm 12V 0.09A) and the unit is working fine again.
Posted on May 01, 2010
I have the same problem and have found a couple of suggestions:
- check each speaker connection individually to find if one is not working correctly
- check that fan is working correctly. One user said that he had to open the machine and just add some oil on the turning wheel of the fan.
Hope any of these tips work. I will try it myself also.
good luck
mariela
Posted on Oct 17, 2008
How do i change the power supply?
Posted on Nov 27, 2007
Ben el muh kmtacl filacngunsrul ,, ,,
Posted on Sep 04, 2008
F61 Means either speakers are wired incorrectly or there is a power supply problem.This detail is shown in the operators manual. Cheers graham
Posted on Oct 06, 2007
Go to turn on or place in CD says" F61" can not use because of error.
F61 Error Solution for the Panasonic SC-AK600 CD Shelf System - if you have any knowledge on electonic just replace the electronic part number #C5ZAZ0000075 you can buy it directly from Panasonic,,, or if you dont have any knowledge on electronic just bring it to nearest panasonic service center.
if this help you please rate me thanks bro...
Jun 04, 2011 | Panasonic SC-AK600 CD Shelf System
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
F61 will not come on
F61 is an error code that shows amplifier output chip is defective and need to be replaced in Panasonic SC-AK640 unit.
Amplifier output chip replacement requires soldering work and local repair shop will do this job as it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Feb 10, 2011 | Panasonic SC-AK640 Shelf System
Hello i get the F61 err on my Panasonic SA-DT100. i have cleaned the fan and it works but still i got the error
Maybe the fan doesn't rotate at the proper speed. Try to put some oil on the bearing sleeve or even replace the fan.
If it offers resistance it will show F61 and disconnect.
Nov 16, 2010 | Panasonic SC-DT100 System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 How to reset SC-HT995W system?
I'm sorry to say, but an F61 error can not be cleared by a reset. Please see the link below for an explanation of protect mode (F61 is Panasonic's version of protect). Usually the output amp pac will need to be replaced. This will cost between $75 and $100 for the part. Feel free to post any additional questions here.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 19, 2010 | Panasonic SC-HT995W System
Panasonic SC-DT100 flat cable
ON SCDT100 has only TV/AUX IN the flat cable is only for Panasonic Devices, so you only option has TV/AUX IN,you need the comb. AV cable from WD media player and connect to TV/AUX INPUT
Jan 17, 2010 | Panasonic SC-DT100 System
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
F61
check the fan
If one fan dosent work it will show the error F61
May 15, 2008 | Panasonic SC-HT940 System
Panasonic SC-DT100 System Logo
737 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
