Question about Dryers
Should there be a pulley on the end of the motor shaft of my hotpoint 9303A tumble dryer?
  • 1,122 Answers
Posted on Dec 06, 2008
I have replaced a new belt on my white knight 3kg tumble dryer 38aw. having done that it now makes a knocking noise or sounds like its catching something does anyone have any idea what it could be
IF there is a 'jockey pulley' fitted to guide the belt', this may not be running true, Or the pulley fitted to the motor shaft may be loose, check & tighten the securing screw which should locate the pulley to the motor drive shaft
Nov 03, 2013 | Washing Machines
Indesit IDC75 belt change
Your tumble dryer is a little different than I am accustomed to, but there are millions of dryers in the U.S. with the same sort of system. Try this. I think ( I hope) the belt goes as follows:
The small black(?) pulley should be spring loaded, so that you can either push or pull it toward you or away from you. I think the belt goes around the motor shaft first, then goes back around the black pulley, then to the drum up above. When you are done, the belt should be upside down S shaped, with the motor shaft in the bottom of the S and the black pulley in the top of the S. I cannot type an upside down S on this keypad. When you pull or push the loose pulley, it should allow the belt to slip by on one side or the other to go around the back of it.
Be blessed.
Apr 27, 2013 | Dryers
How to change belt on Hotpoint CTD00P Tumble dryer
There should be a belt tenstioner and small pulley that is spring loaded if there is not a belt on it the pulley is in the bottom of the dryer.You have to place the tenstioner back in a slot or holder and then the pulley will keep the belt in place.
Apr 22, 2012 | Hotpoint Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
My creda reverseair tumberledryer won';t work. my
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
My amana ned7200tw electric dryer turns on but doesn't tumble/run... the pulley is ok checked that any other ideas
all there is is a belt that turns the drum,the belt goes on the motor pulley around the pulley and around the drum, check the motor pulley to see if it unattached from motor shaft or check the belt to see if it flipped over somehow,there is a smooth side and a ribbed side on the belt and you said the pulley is fine
Nov 07, 2009 | Amana NED7200TW Electric Dryer
Fixed new belt on hotpoint v3d00 tumble dryer now bangs on motor
the rear of the drun runs on a shaft part no 1703038 anythin from £10- £15.00 on ebay just type in hotpoint shaft kit
Feb 10, 2009 | Hotpoint Dryers
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Apr 06, 2008 | Dryers
Tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Mar 12, 2008 | Dryers
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Dryers Logo
Top Dryers Experts
