For instance i put in 62,250/1450 and it gives me 42.93 but it should be 45
SOURCE: My TI-84 Plus gives answer as 2.145274703E14, what Is E?
E is the calculators form of scientific notation. so 2.145274703E14
is really 2.145274703 x 10^14 or 214527470300000
SOURCE: on my TI 83 plus my sine cosine and tangent
Alot of people seem to be having this problem. Angles can be measured
in two units, degrees and radians. Your calculator is currently doing
everything in terms of radians. I have an 84 but I'm sure the 83 is
similar, go under MODE and look for Degrees and Radians and make sure
you choose degrees. if you have to convert, 360[degrees] = 2* pi
[radians]
(easy to remember, 360deg in a circle, 2pi radians in a circle)
Good luck
SOURCE: When I put in the equation (0.75)^45 on my TI-83
the book is wrong then because my ti gives me the same answer
SOURCE: I ask my TI-83 Plus to calculate (-64)^(3/2)
You're both right, in a way. (-64)^3 is -262144. The square root of that is +/- 512i. Take your choice as to the sign.
For what it's worth, the TI-84, TI-86, TI-89, and the HP 50g all go with the negative value.
SOURCE: My TI-83 plus seems to
That is the correct answer. 60 multiplied by 24 is 1440. 1400 divided by 1440 is a number slightly smaller than 1.
Are you sure the problem isn't 1440/(60*24)?
how can i fix it? i need it for an exam plz help...
