Question about Linksys Wireless-G WRT54G Router
I tried setting up my network key but I couldnt find the WEP Key setting button so i went to reset key and eventually I lost my connection.... I couldnt even find now my connection. SO I take my router and plug my computer direct to the server. how can I set-up again my router?
    Genius:
  • 1,061 Answers
Http://www.columbia.edu/acis/networks/aptnet/linksys/index.html.This will explain in detail.with illustrations so you see exactly what is on screen during set-up.i suggest you uninstall all old drivers and go to linksys for currant ones.RICHARDM69
Posted on Dec 06, 2008
Have lost my 3COM network key number
Hello, welcome to fixya.
If by lost your "network key number" you mean the WEP or WPA key that you setup from the router's settings and you use to connect everytime to that wireless router then I would suggest to push the "reset" button on the device (A small pinhole button usually located in the back or bottom of the device).
Doing this, will reset your wireless device to initial factory settings and so you will know the standard WEP key by then. It is written on a sticker on the device along with the SSID,administration console IP/password and MAC address of the router.
NOTE: Resetting factory settings on your router will cause all settings to dissapear (ports forwarded etc.)and will have to be done from the beginning.
Im pretty sure this will fix this type of problem 98% of the time (unless the nature of the problem is different).
Kind Regards from FixYa.
**Please don't forget to vote my solution when you are finished**
Thanks.
Mar 24, 2011 | 3Com OfficeConnect Wireless Router
Tip
Where can I find the WEP key on my router? Router security key, router password
If you have a wireless router at home you will need to have a WEP key setup on your router. WEP stands for "Wired Equivalent Privacy" and WEP is a security protocol used to secure wireless networks. When you setup a router for wireless, you normally specify a key(password) so anyone that wishes to join your network has to enter the key. You normally set the WEP key during the router setup phase. You may have set it up and forgot it, or want to reset it. In this article I will go over the steps to find out the WEP key or change it. Your router may use a different security protocol than WEP so don't worry, you still need a KEY in order to access the network.
-On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is 192.168.1.1 but depends on your router.
There are a couple of ways to find out this IP address.
-Reference your router manual
-In Microsoft Windows, go to Start > Run and in the run box type "cmd" or "command". A black DOS windows should open. In this window, type "ipconfig /all". Look near the top and you should see a "gateway address" item. This number is the ip address of your router.
Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the URL(address) bar, type the gateway address and hit enter(see image below). A log in box should now show. Again, reference your router manual if you do not know the administrative password. Enter in your password and username.
Once you log in you now have access to the router settings and you can configure what you please. What we are looking for in this article is the wireless security settings. In the wireless security settings page you should be able to see the password for your wireless network and change it. If you see no password go ahead and set one up.
**You can also look around and modify other settings. You can change the wireless security, give your wireless network a name(SSID field) and even with some routers have built in testing features to test the connection at home.
I would recommend that if your router has a default password for admin/configuration access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone. People who set up home networks tend to leave this as is and it is a security risk.
TIPS
-If you can't connect to the router and you know the gateway address, try plugging the computer into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.
-Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly.
-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. Please reference router user manual for more information.
I hope this article was informative. Thanks for reading.
Regards,
G33k
Keywords
Where can I find the WEP key on my router?, How to reset router WEP key, lost router security key, where can I find router password, how to reset router password, where to find router security key, how to configure router security, how to configure router password, how to configure router WEP key, lost WEP key, reset WEP key, can't find my pass key, lost router pass key, lost router wireless pass key, how to reset router passkey, how to obtain router passkey
on Jun 01, 2011 | Computers & Internet
I bought a wireless adapter at a garage sale and I do not know the WEP code
The WEP key is set in the wireless router you're trying to connect to, and that's the one you need to know. When you put the adapter in your computer and try to connect, you'll need to provide the code. There's nothing built into the wireless adapter already.
If you're trying to connect to a network and you don't know the key, you'll need to get it from someone who does. Or, if this is your own wireless router and was set up but now you've forgotten the key, you can reset it. There will be a recessed RESET button on the router's back panel. Press and hold it for 10 seconds and release it. The router will restart and all its settings will back to factory defaults. Then you can enter the wireless setup page and create a new WEP key.
Jan 10, 2011 | 2wire (1000-000005-002) 802.11g/b Wireless...
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Network wont show up on any Wireless Network List
Reset your router to factory defaults.
For that press RESET button for 10 seconds it is in back panel of router.
hen connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 10, 2009 | NetGear WGR614 Wireless Router
My xbox 360 wont connect to my friends internet. something bout a wep key. how can i connect?
You need to get the WEP key from the person that setup the network. The WEP key is a password that you setup to prevent outside users from connecting to the wireless network. If you are using FIOS for your internet provider, the WEP key will be printed on the router itself. If you provided your own router, then you need to get in touch with the person that setup the network. If you cannot get the WEP key, then you will need to reset the router to factory default. Most routers have a small button on the back of them. You need to hold the button in for about 20 seconds. This will reset the router to factory defaults. The SSID might  also change to another name too. However, the wireless network should be open after reset and no WEP is needed.
Apr 25, 2009 | Video Game Consoles & Games
I just got a laptop, and i am trying to connect it to tthe router, it's says i need a wep/wap key. where can i find that key?
The wep key has to be created on the router so if you didn't set it up then you need to ask the person who did what it is. Assuming that it is your router and you lost or forgot the key then you can get into the router with a computer that is hardwired to the router. So you plug your laptop into the router and open up internet explorer. In the address bar you need to put in the router's address (Ex: linksys is 192.168.1.1) this will pull up the router menu default login is admin and password admin or root. (if these have been changed then you can push in the reset button on the back but this will wipe out everything and you'll have to set it up again,not preferable.) If you have another router then you can get online on another computer and look these default codes up for your router. If these work then you are in the menu and you can go to security section and create a new wep (or take it off completely again not preferable) make sure to save the changes you have made before getting out of the menu and write down the wep you created or save it in a word doc. Now you can unhook your laptop and try to connect wirelessly when it asks for a wep put in the key you created,reenter it and hit connect and you should be good to go.
Jan 16, 2009 | Computers & Internet
Lost wep key for router
Hold down the reset button for 30 seconds to restore the default settings, it removes all security and the wep key.
Jan 06, 2009 | AT&T 6850G Router (ALL07735)
I am needing the key or WEP to re-connect to wireless
If it was not setup with a WEP key then try "admin" that is the password for Linksys when not set up. The purpose of the WEP key is to install a password to type in before anyone can use your network. So if "admin" does not work then you have to ask the person who set up the Wireless Network what the WEP key is.
Jan 02, 2009 | Computers & Internet
My router isnt connecting to the internet
• Reset the Router to factory default by pressing the Reset button for 10 seconds and then releasing it.
1. Access the Router’s web-based utility by going to http://192.168.1.1 or the IP address of the Router.
2. Setup your router's security i.e wap - wep ...
3. Click the Save Settings button.
Odin
Aug 05, 2008 | Linksys BEFW11S4 802.11b Wireless...
Linksys Wireless-G WRT54G Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
