Question about NetGear WGT624 Wireless Router
Wireless network I have a netgear WGT624 router connects to internet perfectly but my acer laptop will not connect up on the wireless network gets a great signal but just cannot get it to connect (wep is disabled) any ideas? P.S. my other pc connects fine on wireless network My ISP is NTL nad my modem is NTL:250 Model No. E08C007 The laptop will connect to other people's wireless routers with only a small signal but not mine with a strong signal
  • 2,961 Answers
Have you looked at these posted solutions?
Posted on Feb 14, 2007
How can i connect my iphone to my wireless network when i forgot the password! i have netgear wgt624, i tried "password" no joy
you can access the router's wireless settins so that you can check the wireless password or the network key for you to connect your iphone to the internet
Jul 24, 2010 | NetGear WGT624 Wireless Router
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Why does my WGT624 keep loosing connection. I would be on the Internet and for some reason, I would loose connection to the Internet. I have a Dell Inspiron...1521 computer.
In my case too this happened initially with my lenovo y410 laptop with netgeat router. In laptops if th ewireless network is set with "public" profile then the connection is sometimes dropped by the driver. If you or only a few persons are the only user(s) of your router and your WLAN is securely encrypted, then you can change the wireless settings of your laptop to be in "private" network, which will solve your problem.
Oct 31, 2009 | NetGear WGT624 Wireless Router
What steps do I take to allow my 2nd computer, a laptop, wireless connection to internet through my WGT624 wireless router?
>Switch on your laptop wireless..
>Goto Network sharing center from network connection settings menu from control panel..
>Search for New Connection and select your Wifi router And mark it as shared..
Aug 14, 2009 | NetGear WGT624 Wireless Router
Wirless network - laptop
See what ip,gateway and DNS its getting from the access point.If its getting the right ips then your network should work. If it is not getting the right ips then there must be some problem in the DHCP configuration of the access point
Jun 25, 2009 | NetGear WGT624 Wireless Router
Netgear WGT624 router won't connect to the internet
I am in the UK and have found through experience the Netgear's seem to work perfect on a BT line (equivalent of AT & T)
but not on the cable.
I would suggest purchasing a Linksys by Cisco WRT54GL Wireless-G Broadband Router as these seem to install in minutes,
saves me hours of wasted time when setting up wireless networks.
Jan 18, 2009 | NetGear WGT624 Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
Unable to get my other laptop computers to get on the web using my wireless router wgt624
are you using the same settting as the other laptop:
ssid, wep/wpa, wireless channel, and/or encryption key?
is it able to connect to your network? if not then try to directly connect to router using an ethernet cable.
Jun 27, 2008 | NetGear WGT624 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
Wireless connection
NETGEAR Technical Support Engineer 1. access 1st the router's setup page * open up a browser * or 2. go to wireless settings under setup if you have a wireless phone at home change the channel of the router, make sure they dont have same channel 3. change the mode of the router to w/c your laptop's wireless adapter support (eg. b only, g only ) 4. try to change security option wpa instead of wep (make sure your laptop's adapter support it) 5. change SSID (note: if you've change the SSID of the router, remove the profile on your computer under preferred networks 6. change your passphrase 7. Disable Advanced 108Mbps Features 8. Disable Setup Access List (it can be found in wireless settings under advance) 9. upgrade firmware of the router * before upgrading make sure you backup the settings (go to backup under maintenance) * if latest firmware is installed * flush firmware (flushing it is just reinstalling even if the latest firmware is installed) 10. power cycle frequently (turn off for 10 seconds then turn it on again) 11. If all of these didnt work call your laptop manufacturer for help 12. call gearhead -> 1-888-615-3488 13. or call our technical support 1-888-netgear lucky if you got me ***caesar *** NETGEAR technical support engineer
Feb 13, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
113 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
