Question about Epson Perfection V750-M Pro
Scanning images out of focus
The scanner is scanning in focus images and making them blurry. Any idea what I'm doing wrong, or what I can change to combat this. I've checked the images on a lightbox, they are def sharp.
    President:
  • 2,961 Answers
Don't set the scanning at any more than 300 DPI as the human eye cannot recognise any more than this. Next try scanning in through a different peice of software, like Paint shop pro or Word and see if the results are the same. Lastly uninstall the scanner driver and reinstall just to set aside a driver fault, as if the fault is still the same the scanner could be faulty.
Posted on Feb 14, 2007
SOURCE:
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
Old photos scan great into folder on Mac but appear black when transfered to IPhoto on m
hmm..well..that is a little weird..can you supply the operating system for your mac, and also the rev level of image capture?
Oct 28, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
How to adjust the resolution to 300 DPI on an
If you are scanning, you should be able to set the resolution (DPI x DPI) in the scanner configuration. If it is blurry, it could be that the default scan resolution is lower (10 dpi or even 75 dpi).
Settings location will depend on the scanner and software used.
Best scan at an equal (300 dpi) or even higher resolution, so you can scale the image afterwards without quality loss.
Apr 23, 2010 | Microsoft Windows XP Home Edition
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Getting true color on slide scans
Make sure you have the emulsion (image) side of the slide towards the scanner sensor. Some scanners have a special setting for film still in slide holders to correct for focus. You may need a photo edit program to help with color and density. I find no difference from 35mm to split 5x7s altho bigger is always better.
Jul 03, 2009 | Nikon LS-9000 Film Scanner
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Adobe interface issues
We have also seen that Adobe Acrobat doesn't produce very clear scans (with a range of scanners). Adobe gives very good pdf file size but it downsamples images.
Aug 08, 2007 | Ricoh IS 330DC Flatbed Scanner
HELP!!
First off, I'm not too sure if that Printer is a color printer. Its a color scanner yes, but i don't think is a Color Laser Printer! Secondly, can you explain in more detail what kind of scanning and printing issues you have witht the printer? Prints unclear as in blurry or too light? are u having trouble installing the scanner or is it not scanning the images correctly? regards babb
May 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Epson Perfection V750-M Pro Logo
598 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
