Question about HP Officejet 5610 All-In-One InkJet Printer
Officejet 5610xi - Scan or Fax Issues
My all-in-one has worked well until about 2 weeks ago. Now when I scan or fax items (through the automatic paper feeder) I get about 8 or 10 lines vertically throughout the scan.
I tried to scan the same document with bypassing the automatic paper feeder and place it flat on the scanner bed. It was perfect.
What could be the problem with the automatic paper feeder
  • bo_elam1 Dec 07, 2008
    Worked like a charm. The link you provided with detailed instructions and visials really made the difference. It looked like I had a few dots of ink on the glass in the ADF Scanning Glass. Thanks so much
  • 837 Answers
Are teh lines in a pattern that you can see? If so there is something "dirty" .. Have you tried sending a cleaning sheet thru?
Posted on Dec 06, 2008
When using scan feature in my HP 7680 printer any document I scan never scans to its original size, it always shrinks by at least 30%; how can I scan documents to original size?
Try checking your setting. press scan menu (over by the fax buttons) then choose paper size. you may have it on a smaller size. i have mine on automatic. See if that works.
Aug 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
I HAVE A HP OFFICE JET 5610XI ALL IN ONE PRINTER IT WORKED FINE. I ATTEMPTED TO FAX AND IT ACTED NORMAL BUT THE FAX WAS NOT RECEIVED I TRIED AGAIN NO LUCK RAN A TEST IT PASS YET IT STILL WON'TFAX THANK YOU
Hi
I appreciate you work to resolve the issue on your own. I am providing you a weblink to resolve the faxing issue. This web page will help you in graphical way to resolve the issue else you could chat with HP online technician free of cost.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+5610xi+All-in-One+Printer&opname=HP+Officejet+5610xi+All-in-One+Printer&qry=send+and+receive+fax&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=441127&search=0&submit.x=0&submit.y=0
Here is the website which has all the documents about resolving fax issues.
This should resolve the issue
Jan 21, 2010 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 5610xi Solution Center Download?
Please go to www.hp.com and put officejet 5600 in the search bar and you will find the software program for it. If you can't find it there contact me and I will get it for you. 713-204-9111 or 585@snet.net.
Please leave me good feedback if this helped you.
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Need to know abt fax
HP.com has a web page that talks about the different ways you can send a fax from this product:
Faxing Overview
In general, the fax machine in the all-in-one product doesn't need a computer to work. It works just like a stand alone fax machine. You shouldn't have to scan anything in from the scanner in order to fax. Just put the sheet of paper you want to fax into the product's feeder and follow the fax instructions (see the link I posted above).
As long as the product has electric power and is connected to a phone jack, it should work out OK.
As far as legal papers, if you mean legal sized papers, it should work as long as the product supports the paper size you want to use. You can get that on the product specifications web page at HP.
Product Specifications
Once that page opens, go to the Faxing specifications and Paper specifications sections for the relevant details. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Cannot scan anymore. The scanner works but the page is blank. I can copy, fax or pring without any problem. It is a HP all-in-one Officejet 6210
Many known scanner issues of this model by HP.
Most likely uneconomical to repair.
I've tried to fix dozens of these models, but the problem comes back in 2 weeks.
Sep 07, 2008 | HP Office Equipment & Supplies
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
