Question about Philips 170S6FS 17" LCD Monitor
Philips 170s6fs monitor: OSD menu blocked
All time displayed brightness with max. value (100). Neither menu button doesn't work, unless one button for decrease brightness (this button work only when I push them, after I displace my finger monitor automaticly increase brightness on max. Brightnes is always on my scren and I can't remove it.
Please help!
Sorry for my bad english and thank you!
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Posted on Nov 14, 2010
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
My monitor's brightness menu stays always popped up
check the button which get stuck up, clean it with electronic contact cleaner.you will need to remove the back cover to access the button panel.
Oct 15, 2012 | Philips 170S6FS 17" LCD Monitor
Osd main controler lockd
Hi there.
OSD Lockout or On Screen Display Lockout message is that irritating on-screen message that sometimes pops up when you switch on your monitor. This completely locks all monitor settings.
This problem has most likely happened to everybody at some stage or another. Everything has worked fine until now you turn on your monitor and have a message glaring you in the face displaying something about "OSD Lockout". This doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While this problem mainly happens on HP monitors from my looking around I know that others have encountered it on other brands as well. The fixes I provide below should work on those monitors too so don't fear if your monitor isn't an HP model.
The HP Fixes
FIX 1
Plug in the monitor and power it up. Hold down the monitor's Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait a few seconds (just to be sure I'd give it anything around 20-30 seconds) and then try again.
FIX 2
Instead of holding down the Power button, turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
FIX 3
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
FIX 4
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. If your not a seasoned veteran at opening up electronics (and knowing where all the screws go back into) then this could be tricky unless you know what you're doing. Unfortunately there are too many models of monitors for me to give a step by step instruction guide for you. If you have warranty this is where you should use it, I suggest you contact the manufacturer.
The AOC Fixes
FIX 1
Turn off the monitor, hold menu and power button together for 10 seconds then turn back on.
Currently these are the most commeon fixes.
~ Slasher_X
Sep 28, 2011 | Philips 190B6CB/27 19" LCD
I have a Philips 105S5 15" monitor and its OSD is
"OSD Lock" is the On Screen Display Lock, a feature designed to prevent you from accidentally changing any of the settings of the monitor. To disable the OSD lock, press and hold the menu button for 10-15 seconds.
Dec 30, 2010 | Philips Standard 105S Monitor
Screen is too light, how do I darken
Press the 'OSD' (On Screen Display) button on the front/bottom of the LCD, to show a bunch of menu items. Choose "brightness", and adjust it to a darker value.
Jul 20, 2010 | Acer 22" X223w LCD Monitor
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Dec 06, 2009 | Philips 190S7FB 19 inch LCD Monitor
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
OSD Brightness on screen constantly
pls change the contorl buttons ( no 4 )
Jan 04, 2009 | Philips 190B6CB/27 19" LCD
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
OSD menu not working
plz off the monitor for some time. after some time on monitor and check the menu.if not work our osd menu then contact our nearest sevice center bcoz osd chip is damage.
Nov 09, 2007 | ViewSonic VA703B LCD Monitor
Philips 170S6FS 17" LCD Monitor Logo
690 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
