Question about Maytag MSD2656G Side by Side Refrigerator
Refrigerator not getting cold enough
My Maytag RSW22EOD side by side refrigerator does not get cold enough. Compressor running all time, no water in drip pan. The setting on the freezer is at highest. Food frozen in freezer but no frost.
I cleaned coils as best I could, this helped for about 2 days.
I am currently defrosting the refrigerator.
Zmark
  • cowherd101 Dec 30, 2008
    the compressor is fine and no leaks a service man said it was the defroster control panel do you know how to fix it
    Genius:
  • 1,122 Answers
IF THE COMPRESSOR IS RUNNING ALL THE TIME IT CAN ONLY BE THE FREEZER IS NOT MAKING TEMP.OR YOU HAVE A AIR LEAK SOMEWHERE ON THE DOOR GASKETS OR WATER ICE DISPENSER,LET ME KNOW-MIKE
Posted on Dec 06, 2008
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Maytag RSW2700 - S/N R923415 ... has stopped working and is blowing circut. When cirdut reset ,, fridge plugged back in .. blows circut. I have lowered the temp setting, unplugged everything else but the...
Hi, The compressor is not starting and blowing the circuit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 19, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Had no cold at all
heatman101
Apr 21, 2011 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
I noticed that my side by side was not cold enough. I saw an exceess accumutaion of ice on the back and bottom of the freezer. These are the things I've done: vacuumed back and bottom of unit...
heatman101
Apr 01, 2011 | Maytag MBF 2256 Bottom Freezer...
I have a Maytag MSD2433HE. Water runs out of the front whenever it tries to make ice. Also, the ice cubes are only partially formed.
frezer not getting cold enough try cleaning lint buildup on the condesor coils under fridge if clean cheak to make sure compressor is running. if not cheak the relay switchon side of compressor. remove it and shake it if you here a rattle it needs to be replaced
Feb 28, 2011 | Maytag MSD2454G Side by Side Refrigerator
Maytag side by side dripping water out of freezer section, not freezing, doesn't turn off at all
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 21, 2010 | Maytag MFD2560HES Bottom Freezer French...
Refigerator will not saty cold but freezer works
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer not working properly
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
sdfaghsd
Jun 07, 2009 | Maytag MSD2655HE Side by Side Refrigerator
Refrigerator does not get cold enough 50 degrees.
HI,
any further question let me know.
thanks.
Mar 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Wide by side refirgertor side not getting cold
Remember, the control for the cold food refrigerator is merely a vent control.
If you can get no frost on the coils while the compressor is running, you then look at the condenser then the compressor (coolant charge).
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD2656G Side by Side Refrigerator Logo
307 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
