Question about Motorola Mobility RAZR V3
Bluetooth my bluetooth led indicator light on the front of the phone is on, and when io turn bluetooth of it stays on, this quickly takes up the battery life. i have also tried a master reset but the light stays on also if you power the phone off and then back on it still comes on, can anyone help please.
    Problem Solver:
  • 13 Answers
Your flex cable for the upper part of your phone may be faulty. You could try ordering a new one from http://www.cnn.cn and do a relatively simple repair job.
Posted on May 15, 2007
How to extend battery time for i phone?
Ensure any unneeded apps are stopped and not running in the background. Some apps such as facebook / twitter / etc may need to be completely uninstalled or logged out to keep them from running.
Turn down the screen brightness, Generally turning the screens brightness down till it can still be easily seen but not overly bright can increase cell phone battery by up to 20%
Shut off wifi / bluetooth / gps when not required. Disable Wifi / bluetooth, and GPS will also increase your phones battery time.
Ensure a full charge, most devices (iphones included) usually require a minimum of 8 solid hours to charge, even when they say full, they are not actually "FULL". Make sure your device gets at least 8 hours of charge time before use, and don't allow the battery to drain all the way before the next charge.
Nov 17, 2014 | Apple Iphone 4 - 32gb - Black verizon...
Calibrate wii remote
What to do:
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote to be synced. Open the SD Card Slot cover on the front of the Wii console.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the front of the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This sync procedure must be followed for each additional Wii Remote added to the system.
Sep 14, 2013 | Nintendo Wii Console
Wii remote won't sync
  4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This sync procedure must be followed for each additional Wii Remote added to the system.
Mar 08, 2012 | Nintendo Video Game Consoles & Games
Battery life dies out quickly on Nokia 6301...
if you have had your bluetooth on or have been listening to music for a long time that can drain the battery very quickly . the other problem could be if you are not lettting it die of totally then charging it the battery remembers so when you do charge it the battery dont last long . try turning your bluetooth off or just lettin your battery die off totally then charge it fully
Aug 07, 2009 | Nokia 6301 Cellular Phone
Cannot connect to my verizon env2 phone
Try this:
1) Charge the headset (plug it in until the LED light turns off. Didn't take very long for me) and unplug it...
2) Make sure the unit is ON (It blinks quickly when powering on and off, and blinks consistently while on, so it shouldn't be hard to tell) [the power switch is very slim and on the outer edge of the unit, labeled by a circle with a line in the middle]
3) Hold down the big silver button on the large outer flat surface of the unit until the LED light *STAYS ON* ***While that LED light remains solid, the unit is in Bluetooth "Discoverable" mode*** After you have put the hands free unit into this mode, then *promptly* follow your own cell phone's blue tooth pairing instructions, usually found in the "tools" or "settings" menu.
Apr 14, 2009 | Lands Phones
Charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
Aug 25, 2008 | Plantronics Hama Voyager 520 Bluetooth...
I have a lexmark e250dn printer. Today the printer has stopped working. The help ! indicator on the printer is an orange color as well as the toner/and drum indicator is an orange color.The ready indicator...
Here is how to reset the photoconductor kit counter:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
May 25, 2008 | Lexmark Office Equipment & Supplies
Bluetooth LED
take the phone and have the firmware reflash any mobile service center or technician close to you should be able to do that.
Sep 04, 2007 | Motorola Mobility RAZR V3
Blue tooth LED indicator
try going to back to your bluetooth settings and making sure you phones visibility or "find me" mode is turned off. This is a good idea anyway cause anyone can find your phone. Then consider most people don't change their passwords so hacking into your phone and reading your texts and looking at your pictures and even trade things back and forth from their phone to yours!!!
May 08, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
138 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
