Download these things:
DLDI patcher -
http://gbatemp.net/index.php?download=81
NDS Backup Tool Wifi 0.31f -
http://gbatemp.net/index.php?download=2719
Filezilla
https://www.ohloh.net/projects/filezilla/download?filename=FileZilla_3.2.6_win32-setup.exe
--First time only--
Install Filezilla.
Now unzip the DLDI patcher's ZIP into a new folder.
Unzip the NDS Backup Tool ZIP into another folder.
Open up the NDS_Backup_Tool_Wifi.ini file and change the IP address of the DS if necessary (if unsure, leave as is and change it to 192.168.1.10 or 192.168.2.10 if it doesn't work)
Open up the DLDI patcher, drag and drop the NDS_Backup_Tool_Wifi.nds file onto the patcher and then select R4DS (Revolution for DS) from the drop-down menu.
Then, copy over the NDS_Backup_Tool_Wifi.nds file and the NDS_Backup_Tool_Wifi.ini file to your R4's memory card (location doesn't matter).
--After doing the above--
Run the tool and follow its instructions.
When you have followed its instructions and you need to get the game sent to your PC, open up Filezilla then type in the following:
Server: 192.168.*.10 (whatever you chose)
Port: 21 (default)
Username: anonymous
Connect, then look for your NDS file and save it to wherever you want.
Wait for the transfer to complete, then close Filezilla and restart your DS with your R4 inside. Repeat for each game.
