Question about Frigidaire Ovens
Element comes on when it is off
Knob is turned OFF, eye gets red hot, display shows increasing temp. To turn off, we have to cut power at the circuit box.
  • Frigidaire Master
  • 3,463 Answers
You more than likely have faulty oven thermostat..
Only solution is to replace same.
Posted on Dec 06, 2008
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Oven runs hot not responding to temp knob.
refer to your use and care manual and there is a section on adjusting/calibrating the oven temps. tip do not use a small thermometer from the grocery to adjust your oven. buy a decent digital style...... then turn you oven on and let it cycle 3 times, that is elements come on then go off = 1 cycles. then watch the temp scale. record the temp when element turns off,,, then them temp when it turns on. add the 2 temps together then divide by 2 and that gives you the temp the oven is maintaining. then adjust accordingly. DO NOT ADJUST PER THE HIGH OR LOW TEMPS. use the middle temp as described.
Jan 31, 2012 | Ovens
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
My Jenn-air oven won't turn on. It's model number
My Jenn Air 1995 wall oven was working fine until one day the oven and the oven gas burner did not turn ON. I had electricty (make sure you did not trip a breaker) since my front panel LCD and clock was OK. I had a good gas supply.
My oven is an "pilot-less" oven, it uses an electric igniter. Although the "ignitor" was "glowing red hot", the problem is that the gas valve depend on a certain amount of current. If you have a 120V house system, I think the valve needs 3.3 to 3.6 amps to turn on. The current flows through the igniter and then through the valve, as in a same path, like water. So you need an AMP meter to check proper current flow. I read 2.4 amps. I replaced the "glowing red hot" igniter with a new one, Vo"la it was fixed.
Bottom line if you have the oven plugged in OK and you see some life (clock), and you have the gas turned on, most likely the igniter is bad. Second choice would be the oven's thermostat (the temp knob that you turn, say to 350F), or it could be the gas valve.
All three are in same current circuit. The igniter gets the most abuse so I would start there first -good luck!
Sep 24, 2009 | Jenn-Air Ovens
Element will not turn off
Sounds like the contacts inside the switch have welded themselves together. You will need to replace the switch. (the one that you mentioned "clicked" to off) If you like, post an Ask Me with your full model number and I will look up the part number for you. This is a fairly easy repair.
Dec 29, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Bottom /bake element will not come on
Check the connections to the element. If power is going to the element, and it is not working, the element needs to be replaced
Jul 21, 2008 | GE JKP15 Electric Single Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
44 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
