Question about GE DBXR463EBWW Electric Dryer
Dryer do not start
DX2300 GE model do no start a hummm sound first after swich is put on on position, and nothing happens
  • trbond99 Dec 31, 2008
    I have the same problem on a DX2300, I replaced the motor with a new one and tested it without the drum and the motor spun but it would not stay running if i let off the start button. I put the drum and everything back together and it wouldn't spin. So I took the drum back out checked rechecked everything, retested the motor and now the motor won't spin. I only get a hum when i turn it to start.
  • James Shannon
    James Shannon Feb 03, 2014
    I have the exact same problem after installing a NEW motor.
    Genius:
  • 1,122 Answers
IT'S YOUR DRYER MOTOR,IT'S SO WEAK IT WILL NOT TURN OVER,YOU MIGHT FIND A CHEAP ONE ON EBAY-MIKE
Posted on Dec 06, 2008
GE,DRYER,MODEL # DDE5300BALAD
if the bel if the belt breaks the idle pulley will shift actuating when thi when this happens all power t to the dr is shut of
Aug 09, 2012 | Dryers
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
When I turn the start button nothing happens except a buzzing sound...no tumbling happens even if the dryer is empty.
There are two causes for this...bad motor or broken belt... If you are getting a buzzing sound then I would vote for the motor...
Check out a tip that I wrtoe about this...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 31, 2010 | GE DVLR223 Dryers
Ge dryer model #DHDSR46EE1WW. Dryer will not run- just makes loud humming noise. Replaced the start switch and it still will not run at all. PLEASE HELP!
You most likely have a bad motor. Try to spin the dryer drum by hand with the door open, door swich held or taped down, and while pressing start. This will likely get the motor going. If this works try closing the door and starting it again. If it works now the motor may have just had a hard time starting do to it's position or the drum's postition. If it only works when you help it out manually you have a bad motor or maybe a sticky drum/jammed belt/etc. Good luck!
Apr 28, 2009 | General Electric DHDSR46EGWW Dryer
GE DBXR463EBWW Electric Dryer Logo
137 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
